Browse Forums Home Theatre & Automation Re: tv mounting height 2Jan 16, 2011 8:02 pm best way to hide the cable is a having a conduit in the wall. either 32mm or 50mm needs to be rigid type and fixed to the stud. you can either have a bull nose wall plate either end or have a HMDI plug at the bottom and loose cable at the top.. up to you Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: tv mounting height 3Jan 16, 2011 8:50 pm darrell81 i,m putting extra studs in my wall to mount my 50inch plasma.what is the best height to mount the tv. 900-1000mm from the floor [url]ACMA registered cable, Government endorsed Antenna Installer[/url] Re: tv mounting height 4Jan 16, 2011 9:35 pm thanks guys.i have some 50mm pvc pipe left from my ducted vacuum so i,ll use that.i was thinking about using these top and bottom inserted into the plaster board to tidy it up. http://www.powertooldirect.co.uk/trend_ ... -1455.html can i run the audio speaker cables in the same conduit or will it interfere with sound quality Re: tv mounting height 5Jan 16, 2011 10:00 pm darrell81 thanks guys.i have some 50mm pvc pipe left from my ducted vacuum so i,ll use that.i was thinking about using these top and bottom inserted into the plaster board to tidy it up. http://www.powertooldirect.co.uk/trend_ ... -1455.html can i run the audio speaker cables in the same conduit or will it interfere with sound quality a bull nose at the bottom will look 1,000,000,000 x better nah soudl be fine most HMDI's are sheilded Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: tv mounting height 6Jan 19, 2011 7:07 am You don't need extra studs to mount your plasma - not even a 63". Two studs (the vertical ones, not to be confused with noggins which are the little horizontal ones...) are enough to screw the back plate of a typical plasma bracket to - as long as you get at least 2 good/long/big screws into each stud and they pull in nice and hard you have no reason to think it won't hold. The height of the TV can be determined on the day you mount it - no biggie. Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5836 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10665 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7732 |
