Browse Forums Home Theatre & Automation 1 Jan 05, 2011 9:18 pm Rod or someone else i hope you can answer this.. =) Im in the process of building a new house . I have a dedicated room 6m x6m that im setting up a home theater . The room will be painted black.. very dark carpet and a black seating ... How do i black out the windows ?? Has anyone found a full blockout material that i can tac around the windows frame?? It will never be opened so i just need it full block out. Otherwise im considering putting black contact onto the windows .. Any suggestions would be great Thanks heaps .. Mark Re: Blacking out windows.. 2Jan 07, 2011 7:16 am Apart from contact on the windows, we have used Al-foil taped to the windows when we had lighter curtains, this completely blacks out a room - my partner is a night shift worker & learnt this trick working in the mines. Although it doesn't look that attractive from the outside & can be covered with curtains so you don't see it on the inside. Have you considered window shutters? Re: Blacking out windows.. 3Jan 07, 2011 8:59 am Also, try contacting Spotlight and ask for Theatre Curtains. They're a 3 layer blockout. They sell it by the metre. Build thread: viewtopic.php?f=31&t=34120 Handover 23 Dec 11 Squatting 21 Dec 11 Fixed 12 Oct 11 Plastered 31 Aug 2011 Framed 7 June 2011 Site Start 7 Feb 2011 Land Titled 18 Jan 2010 Land Deposit 25 Jun 2009 Re: Blacking out windows.. 4Jan 07, 2011 8:59 am This is what we did in our home theatre room. As we knew it was going to be a dedicated HT room we only had small windows put in. We then hung movie theme canvas prints over the windows. It blocks alot of light surprisingly and makes a real feature in the room. They look like light boxes. It is plenty dark enough in there to watch a movie during daylight hours. Should also add that these are north facing windows. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Blacking out windows.. 5Jan 07, 2011 3:08 pm My own solution to this issue, when I build my next Home Cinema (got some time to wait yet ...), is to install roller shutters on the outside of the windows. To my understanding they go totally black when completely shut, can be opened whenever you want normal daylight coming in, and at least look like a proper addition to the house. Re: Blacking out windows.. 6Jan 07, 2011 4:15 pm I work a lot of shift work and blackening the windows out to sleep during the day is a must. However we just do the cheapy. A black bin bag taped up to the window, then cover that with a blind or curtains so you can't see it. At least this way it isn't permanent. If you want to use the room for something else later on it will take you 5 minutes to remove it. There are also heat reflective foils available that stick on the window. These are a bit harder to remove though. I haven't used or seen any coverings that are aesthically pleasing. Although I am sure there are many on the market. Re: Blacking out windows.. 7Jan 07, 2011 4:27 pm Well-fitting recess mounted roller blinds could work, especially if you fit window trims that extend over the recess a little bit (in front of the blind). The window trims would then block the light that comes in at the edges of the window. To be really sure you could add heavy blockout curtains over the top of that. Or, blockout curtains with linings that cover the entire wall? 4 14300 Unless there is something in special conditions the builder does not have to give you timeline. If your demolition contractor has not removed Asbestos and it was found… 12 28809 Thanks for the informative response! I'll feed that back to the site supervisor. 2 4126 |
