Browse Forums Home Theatre & Automation 1 Dec 24, 2010 9:01 pm Hi, I am in the process of bulding a new home, dedicated HT room - size 4800x4650 The following are the equipments which i would be using 1) JVC X3 3D projector 2) LP Morgan large sized Dipper mount for the projector to be concealed into the ceiling -- however I dont know whether the JVC projector would fit onto this mount 3) Denon AVR 4810 reciever 9.3 4) Paradigm monitor floor standing 11 front speaker, paradigam centre and subwoofer , klipsc f1 surround speakers 5) Panasonic 3d blu ray with twin hdmi player 6) PS3 7) Desktop with hdmi out put I havent yet deceided on the following for which I would require suggestions from u guys 1) The projector screen a) what size? I am thinking fixed screen from EVO 3D screen from oz theatre screen 2) Colour of the walls - ceiling colour? side wall and projector wall screen ---- Thinking of Black for the ceiling and grey for all the walls ---- ur suggestions regarding the walls colours and what sort of black and grey colours to be used? 3) Would like to have a central unit -- like a rack installed in the wall, where I can keep all of my equipments -- and all the wires- hdmi,speaker cable getting connected from this place --- would like to know how I can do this -- 4) I would like to get the wiring done or conduit placed so that I can do the wiring later--- so what should I be telling the builder -- do I tell them to place blank plates which I can replace with the speaker connections plates etc... 5) I would like to know about cat 6 cable--- what can this be used for ? Thank you Merry X'mas Re: Home Theatre, rack, Wiring , Security system 2Dec 25, 2010 10:51 am abraham Hi, I am in the process of bulding a new home, dedicated HT room - size 4800x4650 The following are the equipments which i would be using 1) JVC X3 3D projector 2) LP Morgan large sized Dipper mount for the projector to be concealed into the ceiling -- however I dont know whether the JVC projector would fit onto this mount 3) Denon AVR 4810 reciever 9.3 4) Paradigm monitor floor standing 11 front speaker, paradigam centre and subwoofer , klipsc f1 surround speakers 5) Panasonic 3d blu ray with twin hdmi player 6) PS3 7) Desktop with hdmi out put I havent yet deceided on the following for which I would require suggestions from u guys 1) The projector screen a) what size? I am thinking fixed screen from EVO 3D screen from oz theatre screen 2) Colour of the walls - ceiling colour? side wall and projector wall screen ---- Thinking of Black for the ceiling and grey for all the walls ---- ur suggestions regarding the walls colours and what sort of black and grey colours to be used? 3) Would like to have a central unit -- like a rack installed in the wall, where I can keep all of my equipments -- and all the wires- hdmi,speaker cable getting connected from this place --- would like to know how I can do this -- 4) I would like to get the wiring done or conduit placed so that I can do the wiring later--- so what should I be telling the builder -- do I tell them to place blank plates which I can replace with the speaker connections plates etc... 5) I would like to know about cat 6 cable--- what can this be used for ? Thank you Merry X'mas Hi there. I am a sparky, so I know some of your answers.... Not to sure about the tech specs of your system, however are you building Single or double storey? If it is single you can add your requirements later, (Provided you have a ceiling cavity and not a flat roof) but if it is double storey you need to get all cabling installed before any plaster is installed. Depending on your builder they may not allow you do this your self, or even use your own contractor. There is a higher chance they will allow you to use your own contractor, but they will need the correct insurances. As far as cat6 cabling goes, you can use it to set up a wired home network, installed in pairs you can use special converters to use it for HDMI, and you can also use it for using IR Targets and senders so you can hide your equipment in a cupboard and still use your remote. Cat6 can also be used for phone cabling, and some sprinkler system controls. Don;t be shy in using extra cables needed in the downstairs part of a double storey home... VERY difficult to change things later if you realise you missed something... Best of Luck and Merry Christmas!!!! Re: Home Theatre, rack, Wiring , Security system 3Dec 27, 2010 8:53 am abraham 1) The projector screen a) what size? I am thinking fixed screen from EVO 3D screen from oz theatre screen abraham 2) Colour of the walls - ceiling colour? side wall and projector wall screen ---- Thinking of Black for the ceiling and grey for all the walls ---- ur suggestions regarding the walls colours and what sort of black and grey colours to be used? abraham 3) Would like to have a central unit -- like a rack installed in the wall, where I can keep all of my equipments -- and all the wires- hdmi,speaker cable getting connected from this place --- would like to know how I can do this -- abraham 4) I would like to get the wiring done or conduit placed so that I can do the wiring later--- so what should I be telling the builder -- do I tell them to place blank plates which I can replace with the speaker connections plates etc... abraham 5) I would like to know about cat 6 cable--- what can this be used for ? It sounds like you have some research to do - you give the impression you want to do a lot of this work yourself and yet you also sound very new to a lot of this stuff - you have quite a bit you want to achieve so perhaps you should engage someone who actually has done this before... It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9792 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16268 It seems very clear to me that your contract states that a security account does NOT need to be established so the answer to the builder is NO. If in doubt find a contract… 1 8505 |
