Browse Forums Home Theatre & Automation 1 Dec 21, 2010 9:16 am Hi I'm going to put some in ceiling speakers in the home theater room as well as the living area and the patio. Has anyone had any experience with SpeakerCraft Aim 8 one and three? Are they reasonable for the center and front speakers of a 5.1 or a 7.1 setup? Our "Better Homes Queensland" Cairns Build viewtopic.php?f=31&t=40451 Current stage - 1st builder's clean done. Keys soon. Re: anyone using Speakercraft Aim 8 three's? (or ones) 2Dec 23, 2010 7:34 pm Hi Danrts, I think that if you are looking for a 5.1 or 7.1 system, I would be more inclined to go for cabinet speakers rather than in-wall speakers. Don't get me wrong, some in-walls are great and Speakercraft are among them, but they are always compromised in terms of efficiency, output and don't stand a chance of getting up to anywhere near reference level volumes. You also have the added issue of sound leakage through the walls into other rooms. There are a number of very fine sounding bookshelf speakers that will provide you with excellent sound and have a compact footprint. If you like a more forward sound and high efficiencies, why not look at the Klipsch range of speakers. They are for sale at lots of places including Harvey Norman. Tannoy is another brand that offers excellent price/performance characteristics. Also check out JBL, Mission or even Dali are making some well priced speakers with a good sound. Tempting as it may be, I suggest you stay away from the cheap Chinese speakers that you find on Ebay. They are very compromised and you certainly get what you pay for. As for rear speakers, if you do need to go for in ceilings, check out the range from Selby Acoustics. They are great for the money. For a more sophisticated set up, I have been impressed with the speakers I purchased from Emotiva in the USA. They are an on-wall bi-pole / di-pole speaker which sound very nice, are easy to mount and represent great value. Details at:http://emotiva.com/erd1.shtm Best of luck, Greg Re: anyone using Speakercraft Aim 8 three's? (or ones) 3Dec 24, 2010 8:29 am While I agree with the idea of using traditional cabinet speakers if you are building a reference system (I certainly would), when you are talking reference you are talking about high-end speakers and audio gear. In-wall and In-ceiling speakers are a compromise, for people who don't want the space occupied by traditional cabinet speakers, so if they are willing to make some compromise that includes making some in the area if audio performance - it's not a big compromise, because good In-walls still sound good, but it is a compromise non the less. In saying that, to suggest In-walls cannot go as loud as reference speakers is not always the case. Firstly, many high end cabinet speakers have what I consider average efficiency/sensitivity (~ 88dB), which is also average for most In-wall speakers (and there are some Paradigm In-walls for example that go up to 93dB). And secondly there are also some In-walls that can handle power approaching 200WRMS (still with the 'average' sensitivity of 88dB), which is more than enough to go very loud when driven by a decent amp. If you are talking about high efficiency in traditional cabinet speakers (and simply excellent speakers all round), check out the Paradigm Monitor range... Re: In-ceiling speakers - anyone using Speakercraft Aim 8 3' 4Jan 16, 2011 5:54 am Thanks. The speakercraft Aim 8 3's are rated at 150W power handling. However the receivers I'm looking at include the Onkyo TX-SR608 (175W / channel) and the Onkyo TX-NR708 (185w / channel) Is it going to be an issue that the speaker power handling isn't matched to the receiver power Our "Better Homes Queensland" Cairns Build viewtopic.php?f=31&t=40451 Current stage - 1st builder's clean done. Keys soon. Re: In-ceiling speakers - anyone using Speakercraft Aim 8 3' 5Jan 16, 2011 6:18 am Hi there, you should be fine. Despite popular thinking, most damage to speakers is caused by a lack of amp power and not too much. You may need to consider the efficiency of the speakers. The more efficient they are, the louder they will play at a given power. Unfortunately in walls and ceilings are not particularly efficient unless they have a back box construction. Good luck with your build. Greg Re: In-ceiling speakers - anyone using Speakercraft Aim 8 3' 6Jan 19, 2011 7:00 am Tom's Playroom Unfortunately in walls and ceilings are not particularly efficient unless they have a back box construction. One area where they can fall behind a little is in their power handling, most likely due to the restrictions they face in designing the drivers (they typically can't afford to be any more than 80-90mm deep), which will obviously mean they can't be driven as hard and therefore ultimately won't be able to be pushed to louder volume levels, but this is still more attached to the more affordable In-walls. Perhaps think about it this way: If you would consider spending $1500-$2000 on a pair of floorstanding speakers you should also consider the quality and capabilities of some equally priced In-walls... As an example, the Paradigm SA-35 In-walls (below) out-perform MANY equivalently priced floorstanders - RRP $1799 pair - but then they are Paradigms http://www.paradigm.com/products/paradi ... ries/sa-35 Re: In-ceiling speakers - anyone using Speakercraft Aim 8 3' 7Jan 19, 2011 11:49 pm Hi Danrts, i know the speaker you are talking about and they are very good, conventional speakers are better but don't look as good in a room. i use 7 Tannoy system 1000 series, they are very ugly in the room but sound amazing. few tips, high sensitivity does not mean quality but if you do get something around the 88 bd you need a good amp, every 3 db you will notice the volume difference. High 90bd speakers need less power to run being more efficient, you should try to use the same speaker in all 5 or 7 locations, this will give you better imaging between front rear left right and centre. good luck Re: In-ceiling speakers - anyone using Speakercraft Aim 8 3' 8Jan 20, 2011 9:00 am Rodda Tom's Playroom Unfortunately in walls and ceilings are not particularly efficient unless they have a back box construction. One area where they can fall behind a little is in their power handling, most likely due to the restrictions they face in designing the drivers (they typically can't afford to be any more than 80-90mm deep), which will obviously mean they can't be driven as hard and therefore ultimately won't be able to be pushed to louder volume levels, but this is still more attached to the more affordable In-walls. Perhaps think about it this way: If you would consider spending $1500-$2000 on a pair of floorstanding speakers you should also consider the quality and capabilities of some equally priced In-walls... As an example, the Paradigm SA-35 In-walls (below) out-perform MANY equivalently priced floorstanders - RRP $1799 pair - but then they are Paradigms http://www.paradigm.com/products/paradi ... ries/sa-35 Hi Rodda, I do agree with you about the Paradigm speakers. I have heard them and was blown away by their performance (actually heard them in Canada at a friend's place and they sounded special. But then he was driving them with large Classe amps. When you spend 13k on each amp, I would expect a pretty rich sounding system. However, if the budget stretches this far, I could not think of a better sounding in-wall for the price. However, there are a million lesser quality in-walls and in-ceilings available that claim to offer the finest in audio performance and whilst I understand the need to compromise for aesthetic reasons, so many people put in-walls in only to find that ultimately they are a little disappointed with what they can do. With regards to published efficiency figures, I do tend to agree with you, but there is still the issue with physics. Maybe I have misused the term 'efficiency' in the strictest term. I was relating rather to the volume of the speaker in relation to it's input. I don't claim to be an expert in speaker physics and am happy to be proved wrong, but from my layman's understanding, in order for a speaker to generate high volumes, it needs to move large amounts of air. The inside of a wall cavity is a large amount of air but is hardly a particularly effective 'enclosure', with leakages between joists, irregular shapes etc. Likewise, unless the backing box manufactured with the speaker is of a similar size to a well tuned cabinet, then it is a physical impossibility for that speaker to move enough air so as to reach the volume levels of a larger, floor standing speaker. Of course, you will get arguments from the proponents of Bose speakers (sorry to those who have spent a fortune on this equipment ). Not being argumentative and maybe your experience with in-walls has been more favourable than mine. I am just of the opinion that if you are going for a nice set up with projector and large screen, sound is a major part of the experience and I would be let down after cutting holes in my walls to have anything less than 'BIG' sound from my speakers. Re: In-ceiling speakers - anyone using Speakercraft Aim 8 3' 9Jun 18, 2012 4:48 pm maxweber ceiling speaker's are really only used for music.I've speakercrafts crs6 they sound excellent , watching twister (blu-ray release) its disgustingly loud and clear. Ceiling speakers should never be used for music, it's more for sound effects AKA home theatre sound effects. No meant to be harsh, but anyone uses ceiling speaker for music should be shoot. There is nothing beats a good dedicated 2 channel floor standing speakers for music listening, in saying that, if you're really into music, a clock radio is just as good. Built: Modified H3nl3y S0h0 Q1 in Melbourne :- Never again Re: In-ceiling speakers - anyone using Speakercraft Aim 8 3' 10Jul 13, 2012 11:25 pm EmeryBB Ceiling speakers should never be used for music, it's more for sound effects AKA home theatre sound effects. No meant to be harsh, but anyone uses ceiling speaker for music should be shoot. There is nothing beats a good dedicated 2 channel floor standing speakers for music listening, in saying that, if you're really into music, a clock radio is just as good. I would definately disagree with this statement it is far to general! Have you had the please of hearing these from Krix? http://krix.com/Product/Detail.aspx?p=44&id=85 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 0 2167 Broker here - legislation says that every true broker must put the clients best interests before theirs so in theory they must offer you the best options for you on their… 2 46172 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6100 |
