Browse Forums Home Theatre & Automation 1 Dec 07, 2010 8:51 pm I connected TV cable from bottom of wall which is then connected to power up to TV that will hang from the wall, I also placed HDMI cable from Amb to same spot… I also placed aerial cable in same spot to plug straight in the TV BUT electrician is saying I should have had aerial connection down the bottom where Amb and power is and connect aerial through amb?? This will also help when foxtel goes in??? is this correct??? If so DAMM DAMM Hope this makes sense.... Cheers Re: Have I stuffed up??? 2Dec 08, 2010 10:37 am well I'm confussed... maybe draw a picture or post a picture and amb = amp ? as in amplifier? as in AV Receiver (it has an amp inside of it aswell as control feature so you can do vision / audio input switching but also amplify the low level of Line signals to be able to be played in Speakers) Amplifier = Generally, an amplifier or simply amp, is any device that changes, usually increases, the amplitude of a signal. The relationship of the input to the output of an amplifier—usually expressed as a function of the input frequency—is called the transfer function of the amplifier, and the magnitude of the transfer function is termed the gain from http://en.wikipedia.org/wiki/Amplifier AV Receiver = AV receivers or audio-video receivers are one of the many consumer electronics components typically found within a home theatre system. Their primary purpose is to amplify sound from a multitude of possible audio sources as well as route video signals to your TV from various sources. The user may program and configure a unit to take inputs from devices such as DVD players, VCRs etc. and easily select which source he or she wants to route to his TV and have sound output for. From http://en.wikipedia.org/wiki/AV_receiver Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Have I stuffed up??? 3Dec 08, 2010 10:52 am No, you haven't stuffed up. Unless you have some new, wizz-bang amp that has a TV tuner built into it you don't plug your TV antenna connection into your amp (** exception - if the amp has an FM tuner in it you can get FM reception from your TV antenna. Then I recommend splitting off a connection that you can use for your amp if you want). I suggest you run the TV antenna connection directly into your TV, unless you have an external recorder (PVR/HDD recorder) which will then need an antenna connection also. But even then, I still suggest an antenna connection directly into the TV so it can be used without having to turn any other piece of equipment on (if you just want to watch FTA TV...). Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39714 Hi All, I just wanted to close this topic out with an update. So we ended up agreeing to a number with the insurance company, and after an extensive amount of hand… 8 23401 You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18063 |
