Browse Forums Home Theatre & Automation 1 Nov 23, 2010 1:31 pm As i understand the new generation Apple TV only has a HDMI connection, while this is fine for my tv's, my amp for my speakers that are in my outside entertainment area where I'd like to stream music, only have the RCA plugs. Is there a way to connect an Apple TV to this amp using some sort of adapter? Or is it impossible to go from digital to analog without some sort of decoder? Anyone done this? Or is there a solution? Re: hdmi to rca audio 2Nov 23, 2010 2:46 pm kingwally Is there a way to connect an Apple TV to this amp using some sort of adapter? Or is it impossible to go from digital to analog without some sort of decoder? Anyone done this? Or is there a solution? you will need a decoder of some kind... eiother an amp wtih HDMI in Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: hdmi to rca audio 3Nov 26, 2010 4:44 pm Even AVRs that can take mutliple analogue inputs and convert them to HDMI usually cannot do the same in the other way (HDMI --> analogue), and they cannot play a digital audio source to their 'Zone 2' etc. areas, only analogue sources. You will need a HDMI to RCA 'Down-converter", something like this: http://www.atlona.com/Atlona-HDMI-DVI-t ... erter.html or this: http://www.gefen.com/kvm/dproduct.jsp?prod_id=5280 or this: http://www.bhphotovideo.com/c/product/6 ... tereo.html |
