Sound insulation - villaboard cf sound check
In 1 room the other side of the stud wall is the inside of a cupbord/wardrobe so the finish isn't really an issue.
On the other side of the filled in doorway will be bedroom wall. The rest of this wall is rendered single brick and I don't intend to reline the whole wall so it will always look different to the wall finish.
The bathroom will have Villaboard 12mm on one side then SoundScreen rockwool batts in the cavity for insulation and sound proofing. The question is what should I use on the other side of the wall, Villaboard 12mm or Sound check?
Builder suggested using Villaboard 12mm on the other room side instead of Sound check 10mm or 13mm.
How much difference will that single layer of Sound check / Villaboard 12mm make to transmission of sounds?
How do you keep the insulation off the villaboard? Use a sheet of viscreen/builders plastic?
3
If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with…
5/12/2023
Hi All, First time poster. I was hoping to get some advice on villaboard installation within a bathroom. I have installed villaboard before, in a laundry. I think I did…
20/06/2023
9
i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were…
