Browse Forums Home Theatre & Automation 1 Nov 16, 2010 9:44 am Gday all, Currently building and have run multiple services back to my hub (Yes I have an open ticket and have had it for 8 years ) Most of the work I have done has been in commercial enviroments with large server air conditioned rooms. In this case for my house, this tiny room is not well ventilated. In fact zero. I have all Data, Coax, Audio, Alarm wiring back to this location, including the T/O from the street. This is where I plan to have my router and power supply units, dvr, ups etc so you can imagine the heat this room that can build up. Is there a exhaust/ ventilator that can be mounted to the ceiling that runs 24/7, is quiet and very reliable and suitable for such a scenario? Re: 1m x 2m mini sever room - Ventialtion/Heating issues adv 2Nov 16, 2010 10:13 am These are quite but dont know about very reliable or running 24/7... worth a look: http://www.panasonic.com/business/building-products/ventilation-systems/pdf/CrossReference07.pdf Cheers Cozmo ______________________________ Building a PD Heywood 29 http://fromevetoeternity.blogspot.com/ Re: 1m x 2m mini sever room - Ventialtion/Heating issues adv 3Nov 16, 2010 8:36 pm I seem to remember someone a while back had a little setup that included a heat sensor which would turn on an exhaust fan when his server equipment got too warm. Re: 1m x 2m mini sever room - Ventialtion/Heating issues adv 4Nov 17, 2010 8:46 pm kexkez I seem to remember someone a while back had a little setup that included a heat sensor which would turn on an exhaust fan when his server equipment got too warm. Would bloody love to find out what that is Re: 1m x 2m mini sever room - Ventialtion/Heating issues adv 5Nov 17, 2010 9:00 pm Frappe kexkez I seem to remember someone a while back had a little setup that included a heat sensor which would turn on an exhaust fan when his server equipment got too warm. Would bloody love to find out what that is Sounds like something you could do yourself.... maybe a trip to jaycar is in order if your that way inclined Cheers Cozmo ______________________________ Building a PD Heywood 29 http://fromevetoeternity.blogspot.com/ Re: 1m x 2m mini sever room - Ventialtion/Heating issues adv 6Nov 17, 2010 9:17 pm If you want fit a thermostat for the fan, keep in mind two things: -At what temperature do you want it to turn on? -How will I know if it has failed to turn on? After years of dealing with computer and telecommunications installations that used fan forced air, the continually running fan wins hands down-one less thing to break with no thermostat and you get to learn what noise should be comin from the gear after a while. Re: 1m x 2m mini sever room - Ventialtion/Heating issues adv 7Nov 17, 2010 9:30 pm It was Rikster page one of this thread and includes a photo he uses "a bathroom ceiling extractor in there connected to a thermostat" viewtopic.php?f=31&t=16014&p=196125&hilit=server+hub+exhaust+fan#p196125 Re: 1m x 2m mini sever room - Ventialtion/Heating issues adv 8Dec 02, 2010 9:50 am It really depends on the house design and stuff, but you generally want to keep servers and such in a room of about 21 degrees. Obviously it's not as critical in a home environment as a big organisation, but if you've got critical infrastructure like alarms and stuff running from that room you'd want it reasonably cool. Having a mini-split system air conditioner is probably muchos overkill, but it all depends on how serious you are! Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: 1m x 2m mini sever room - Ventialtion/Heating issues adv 9Dec 02, 2010 2:17 pm kexkez It was Rikster page one of this thread and includes a photo he uses "a bathroom ceiling extractor in there connected to a thermostat" viewtopic.php?f=31&t=16014&p=196125&hilit=server+hub+exhaust+fan#p196125 and aslong as you have made ajustments inthe power plan then adding this during construction is easy or not making sure you can add it late ron..general domestic gear will be fine as longas there is some air movement this is my current set up Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: 1m x 2m mini sever room - Ventialtion/Heating issues adv 10Dec 09, 2010 1:18 pm That's a wicked little home-job. Just the fans would wipe heaps off the operating temperature of those devices. I like it. Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 I am looking at building a house. Has anyone used Construkt Homes (based in Adelaide)? Does anyone have experience with this builder? 0 6450 12 5320 Industry type domestic contracts are prepared by industry bodies for the benefit of the builders. This means that if you are the owner watch out. One of the points is… 0 3225 |
