Browse Forums Home Theatre & Automation Re: iPad connectivity question 21Nov 08, 2010 8:32 am ok great thanks Machiars! I'll let you know when I get it. they said before the end of this month, so might be a couple of weeks away. "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: iPad connectivity question 22Nov 18, 2010 9:19 am just picked up my iPad it's still in the box, I can't wait to have a play with it later. I hope I have time, have a school meeting tonight. "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: iPad connectivity question 23Nov 18, 2010 9:40 am is it 3G + Wifi? It should say on the back of the box. Re: iPad connectivity question 24Nov 18, 2010 9:47 am I just had a look... it says this... MB292X/A iPad WI-FI 16GB-AUS so no 3G? what does this mean? it doesn't take a sim card? so I can only use it at home? (it also says Includes ipAd, DOck Connector to USB Cable, and 10W USB Power Adapter. Supports Wi-Fi (802.11a/b/g/n) and Bluetooth 2.1 + EDR) "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: iPad connectivity question 25Nov 18, 2010 12:21 pm yes that means no 3G.. that is the base model. Is still a great device though but you will have to sort out your wifi modem issues at home.
Re: iPad connectivity question 26Nov 18, 2010 12:41 pm yes I will, I might be calling out for help with that later "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: iPad connectivity question 27Nov 18, 2010 8:59 pm ok I've plugged it in. It seems to want me to download itunes. ok fine. so it's connected to my laptop now, I tried to open itunes on my laptop - hadn't done that in a while and it told me it couldn't find QuickTime so could I please uninstall itunes and install it again. so I've done that (probably losing all my music in the process ) so I really have nothing IN itunes to sync to the ipad. not sure what to do next... "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: iPad connectivity question 28Nov 18, 2010 9:58 pm You need to connect it to itunes to activate it before you can use it. So once itunes is installed it will activate and then it should pick up your wifi network automatically when you go to do anything on the net with it. You then type in your wifi password and you should be connected. Re: iPad connectivity question 29Nov 19, 2010 7:46 am thanks andy, I managed to do the itunes installation & sync, and it didn't lose any of my music yay! so it's working, and it's picking up our wifi connection but DH & I have both forgotten the password!!! anyone know how we can find it out? "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: iPad connectivity question 30Nov 19, 2010 8:09 am donuts thanks andy, I managed to do the itunes installation & sync, and it didn't lose any of my music yay! so it's working, and it's picking up our wifi connection but DH & I have both forgotten the password!!! anyone know how we can find it out? be on the router... and to prevent you "forgetting" in the future, what i do for all my family is create a text file with all the important info including Modem/router IP addy: < so somethign like 192.168.1 < not my actual IP addy btw Modem/ Router Admin Login User name: Admin < is the most defualt user name Modem/ Router Admin Login Password: <what ever that is Wifi details: SSID: < what ever you have used either defualt or yopur own custom name PassKey: < what ever that is great place to simply copy and paste Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: iPad connectivity question 31Nov 19, 2010 8:28 am thanks Pugs, yes we did have such a text file ... on the dead laptop!!! so when you say it will be on the router, what do you mean exactly? how to get the password will be written on the actual router?? sorry I'm a bit clueless... "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: iPad connectivity question 32Nov 19, 2010 8:37 am You need to type the I.P address (look into the manual) of the router in your browser to access your router and you should be able to access it and retrieve your password from there. Worst case, you still can reset your router to factory default settings and set it all up again so then you write the password down. Re: iPad connectivity question 33Nov 19, 2010 9:12 am or just type "cmd" in run and then type "ipconfig" into the cmd prompt. It will then say what your gateway is. That is your routers IP address. iPad connectivity question 34Nov 19, 2010 11:59 am Try putting this IP into Internet Explorer. 192.168.2.1 This is usually the default Router Ip for the model you have. I believe by default your router type has no password. So with luck that hasn't been changed. Click Submit. If this works on the lefthand side there should be a section that says wireless. With the wireless password most likely being in the "Channel and SSID" section. I'm on my phone so can't post a more informative post. If you need more detail bounce me a PM. Re: iPad connectivity question 35Nov 19, 2010 12:20 pm thanks guys... Machiars I just saw your pm before reading this post.. will hav a look hold on... "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: iPad connectivity question 36Nov 19, 2010 12:26 pm Hi Machiars, I've done what you said. Where it asked for a password, i pressed submit instead, it has come up with a whole lot of information but nothing that looks like a password... I'm confused... you think maybe I don't have a password to access my password, but I do need a password to access the internet? "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: iPad connectivity question 37Nov 19, 2010 12:33 pm oh oh oh! i think i found it! it was under "security" screen. will just get the ipad out and try it!!! "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: iPad connectivity question 38Nov 19, 2010 12:36 pm eeeeeeek! it's working!!!!! thanks SO much Machiars!!! and everyone else. just browsing some apps now "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: iPad connectivity question 40Nov 19, 2010 12:45 pm Hello from my iPad!!!! Geez I'll probably never leave the house today now!!!! "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Hey I just purchased an apple ipad to use on site. If you are using an ipad on site, I was wondering what you all are using for construction related apps to make site… 0 1613 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9959 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6151 |
