Browse Forums Home Theatre & Automation 1 Nov 01, 2010 3:01 pm Hi, this is our media room, it's 5.6 x 4.5. I'm thinking of having the TV on the left wall (probably a large LCD). We have windows on the outside as the pool is out there. I'm hoping to eventually install a surround sound set up. While floor standing speakers are good I'm worried small children may knock them over and disrupt the setup so I was thinking of ceiling bracketed speakers. In terms of pre-wiring, would you just run conduit down from the roof cavity to where approx. the amp would be placed? NB the wall is 70mm thick per the plan. ceiling is 3m high. http://i69.photobucket.com/albums/i80/danielt25/New%20House/mediaroom.jpg Our "Better Homes Queensland" Cairns Build viewtopic.php?f=31&t=40451 Current stage - 1st builder's clean done. Keys soon. Re: media room pre-wiring / setup 2Nov 03, 2010 6:09 pm Hi Darnts, Are you able to do the wiring before the plaster boards go up if Yes why dont you just wire the room, mark or take photos of were the wire's are and later on when the house is complete and you are ready, cut into the boards to use yr wires?> Use wall plates etc.. Serentity We've had the offer of a short term tenant whilst waiting for CDC/DA home approval and demolition for our knock down rebuild. It would achieve a pretty low rent as it's… 0 14098 The fastest thing a builder will do is bank your cheque, those systems work perfectly with lightning speed, everything else is slow burn. Just the way it is. 1 9116 Just to makea point about this, an approach that some people have found sucessful in negotiating these rises down, Is to provide some workings to the builder, specifying… 4 82196 |
