Browse Forums Home Theatre & Automation 1 Oct 29, 2010 2:33 pm I just wanted to know if anyone has had any experience with getting fibre optic to the home. The estate that we will be moving to has this as standard and I want to understand the intricacies of this. I have alread been hit with an 'upgrade' of the convertor unit as I was told that the standard one doesn't allow more than a single video, LAN & voice outputs. As I have had no exposure to these technologies (even though I'm an IT worker) I just nodded my head and said 'yes', I'll pay for the upgraded unit. My view is that I would like to wire up my whole house with CAT5 but I've been told this isn't possible with fibre (which I highly doubt). Any thoughts or experience in this area would be appreciated. Thanks in advance Project History Deposit - 20/4/2010 Land Settled - 20/8/2010 Council - 30/9/2010 Slab - 17/11/2010 Bricks - 28/01/2011 Roof - 5/02/2011 Gyprock - 4/03/2011 Re: Fibre Optic to the Home - Share your experience 2Oct 29, 2010 5:36 pm Hi qonyx, A good overview of the FTTH set up is on the Telstra site: http://www.telstra.com.au/smartcommunity/assets/telstravelocityhomewiring_1108.pdf The fibre terminates @ the ONT & is then taken to the HDU (Home Dist Unit), something like Clipsal Starserve: http://www.clipsal.com.au/trade/downloads/brochures/clipsal_datacomms/starserve_home_networking_system which splits the data into POSTN, FTA TV, Foxtel & internet. Plug in a modem/router & set up your network with Cat 5/6 or ??? Got a life, just can't find it! Re: Fibre Optic to the Home - Share your experience 3Oct 31, 2010 6:44 am thanks that helps.. does anyone actually have it installed? what has your experience been? Project History Deposit - 20/4/2010 Land Settled - 20/8/2010 Council - 30/9/2010 Slab - 17/11/2010 Bricks - 28/01/2011 Roof - 5/02/2011 Gyprock - 4/03/2011 Re: Fibre Optic to the Home - Share your experience 4Oct 31, 2010 7:35 am Cat5 is so 5 years ago, Cat6 or higher FTW. and btw they wont let you personally install the cables you will need to find someone with their data ticket, PLI and such to install them. Not have it installed but Have Installed it into at least one Clients house so far. I have a few more lined up. and btw it is Cat5e, Not Cat5 Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Fibre Optic to the Home - Share your experience 5Oct 31, 2010 9:32 am You can find a lot more info http://forums.whirlpool.net.au/forum-replies.cfm?t=1527442 There is a guide that has been compiled but can't find it currently. A bit more info http://www.ozcableguy.com/cabling.asp We are having the Starserve installed but am currently only @ council approval stage so can't comment on experience. I have seen mention that there are better choices than Starserve but builder isn't interested in offering us other options. Got a life, just can't find it! Re: Fibre Optic to the Home - Share your experience 6Oct 31, 2010 9:39 am nrh157 You can find a lot more info http://forums.whirlpool.net.au/forum-replies.cfm?t=1527442 There is a guide that has been compiled but can't find it currently. A bit more info http://www.ozcableguy.com/cabling.asp We are having the Starserve installed but am currently only @ council approval stage so can't comment on experience. I have seen mention that there are better choices than Starserve but builder isn't interested in offering us other options. Find a cabler that your Builder will let on site and then tell them to stick star serve where the sun doesn't shine... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Fibre Optic to the Home - Share your experience 7Oct 31, 2010 9:45 am thanks for the responses NRH and PUGS, so am i hearing that it won't be possible to wire up with cat5e by myself even if the builder let me? or i may need some pretty technical expertise in doing this? Project History Deposit - 20/4/2010 Land Settled - 20/8/2010 Council - 30/9/2010 Slab - 17/11/2010 Bricks - 28/01/2011 Roof - 5/02/2011 Gyprock - 4/03/2011 Re: Fibre Optic to the Home - Share your experience 8Oct 31, 2010 10:14 am qonyx thanks for the responses NRH and PUGS, so am i hearing that it won't be possible to wire up with cat5e by myself even if the builder let me? or i may need some pretty technical expertise in doing this? The builder has no idea I would run away from them very quickly... No, but if they would let a suitably trained person onsite at your request by the sounds. Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3125 Approvals are covered in the cost we are paying to the pool company. The only thing stated in our home build contract for the additional cost is engineering support. … 3 7101 traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4138 |
