Browse Forums Home Theatre & Automation 1 Oct 23, 2010 6:24 pm Hi, I need advice on replacing the TV aerial socket. It's obviously well & truly past its use-by-date Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Could someone suggest a ballpark figure to have it replaced by an electrician ? Are we talking $50, $200, ???? Doesn't need to be accurate, just your guesstimation, please. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Replacing old TV aerial socket 2Oct 23, 2010 7:23 pm Southies Hi, I need advice on replacing the TV aerial socket. It's obviously well & truly past its use-by-date Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Could someone suggest a ballpark figure to have it replaced by an electrician ? Are we talking $50, $200, ???? Doesn't need to be accurate, just your guesstimation, please. not only wall plate needs to be replaced, but I would suspect that also ribbon type of cable needs to be replaced all the way to the antenna, and possibly 30-40 year old antenna as well. More likely $200-300 than $50. [url]ACMA registered cable, Government endorsed Antenna Installer[/url] Re: Replacing old TV aerial socket 3Oct 23, 2010 7:49 pm Pop the plate off the wall, it may have 75 ohm coax run down the wall and might have a 75 to 300 ohm balun on the back of the plate. The old 300 ohm ribbon was fairly strong, if you're lucky it may make for a good draw wire. Better still, have a look at your antenna and see whats running off the antennas connector. This will save you having to tear stuff off the wall. The old HPM 889 series power outlet is around 40 years old, whilst the sparkie is there a replacement could be done-saves a second trip. Re: Replacing old TV aerial socket 4Oct 24, 2010 7:22 am That's a lot to take in - wasn't expecting such detailed replies - thanks guys !!! Will get DH to read htis as I"m sure he'll understand some if not all that you're saying Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Replacing old TV aerial socket 6Oct 12, 2011 6:09 am strathos Hi, I have the same problem in my unit. Were you able to replace the socket with a new one? How much did it cost you? Should my landlord pay for the cost? Thanks. Does it no longer function? In which case it wouldn't be un-reasonable to expect the landlord to replace it. If it is still functional then why does it need to be replaced? Re: Replacing old TV aerial socket 7Oct 12, 2011 3:15 pm AJW strathos Hi, I have the same problem in my unit. Were you able to replace the socket with a new one? How much did it cost you? Should my landlord pay for the cost? Thanks. Does it no longer function? In which case it wouldn't be un-reasonable to expect the landlord to replace it. If it is still functional then why does it need to be replaced? If you are in a unit, then it is likely that the body corporate is responsible for the antenna cabling, rather than the land lord directly. With the pending end of analog TV transmission there are a large number of unit blocks that are going to have to replace/upgrade their antenna systems and cabling to support digital UHF transmission. Paul Hi, we live in an area where the black soil is prone to a lot of movement. We have an old 50's house with masonite everywhere and nails popping out, warping, rusted etc.… 0 4514 2 8366 Yes, get a builder, make sure he is experienced and a registered building practitioner 5 8978 |
