Browse Forums Home Theatre & Automation 1 Oct 18, 2010 10:25 am Hello all. Need your thoughts please. Attached is my plan. http://www.scottparkhomes.com.au/metro/ ... iewBro.pdf I have one conduit running in all rooms and pargola outside. What I am looking to do is to have a control panel in the Garage which can distribute all to the rooms then but must do the items below: Pay TV in living room with decoder to change channels but then send signal to central unit in garage and then to split it to 2-3 rooms. Standard tv point already in all rooms. Internet Network cable running from PC in study room to hub then split it running to Master room,cinema and room 3 want to have PC rack in garage then just have monitor printer mouse and keyboard in room. what is the best central hub with LOTS OF splitters that I can use? and potential for additions. I saw the engineering post seems way beyond my capability. Re: Help Home Automation selection. 2Oct 21, 2010 3:48 pm sij Hello all. Need your thoughts please. Attached is my plan. http://www.scottparkhomes.com.au/metro/ ... iewBro.pdf I have one conduit running in all rooms and pargola outside. Maybe not enough Conduits, Pay Tv 2 coax 1 x Data, TV 1 x Coax, IPTV 1 x data, RF modulation 1 x coax. too many for one conduit What I am looking to do is to have a control panel in the Garage which can distribute all to the rooms then but must do the items below: Pay TV in living room with decoder to change channels but then send signal to central unit in garage and then to split it to 2-3 rooms. RF Modulation, Analogue device, pictures not great but works ok Standard tv point already in all rooms. need data for IP tv Internet Network cable running from PC in study room to hub then split it running to Master room,cinema and room 3 want to have PC rack in garage then just have monitor printer mouse and keyboard in room. Minimum of 3 data, phone, internet, networking from that PC or other option is from the panel what is the best central hub with LOTS OF splitters that I can use? and potential for additions. Starserve pro is good, have a look at that. also make sure you can connect NBN if it ever happens I saw the engineering post seems way beyond my capability. Re: Help Home Automation selection. 3Oct 21, 2010 3:49 pm Barrywalters sij Hello all. Need your thoughts please. Attached is my plan. http://www.scottparkhomes.com.au/metro/ ... iewBro.pdf I have one conduit running in all rooms and pargola outside. Maybe not enough Conduits, Pay Tv 2 coax 1 x Data, TV 1 x Coax, IPTV 1 x data, RF modulation 1 x coax. too many for one conduit What I am looking to do is to have a control panel in the Garage which can distribute all to the rooms then but must do the items below: Pay TV in living room with decoder to change channels but then send signal to central unit in garage and then to split it to 2-3 rooms. RF Modulation, Analogue device, pictures not great but works ok Standard tv point already in all rooms. need data for IP tv Internet Network cable running from PC in study room to hub then split it running to Master room,cinema and room 3 want to have PC rack in garage then just have monitor printer mouse and keyboard in room. Minimum of 3 data, phone, internet, networking from that PC or other option is from the panel what is the best central hub with LOTS OF splitters that I can use? and potential for additions. Starserve pro is good, have a look at that. also make sure you can connect NBN if it ever happens I saw the engineering post seems way beyond my capability. Re: Help Home Automation selection. 5Oct 24, 2010 11:18 pm sij so what 2 conduits or 3 per area? 1 for pay tv,1for networking one normal tv,1 modulator 3 cables in 1 25mm conduit, does that help? Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28814 Hi there, we have classic cream gutters, fascia’s, roller door and undercover carport. We are are going to paint the roof a terracotta orange colour. After some… 0 4503 Hi Kaiser85, We are building with Firstyle Homes. Our build has just started, slab pour is on Saturday (hopefully!). Their standard range is pretty good. We did our… 1 6493 |
