Browse Forums Home Theatre & Automation 1 Oct 17, 2010 10:43 pm I've heard from several electricians that they prefer Clipsal wall plates to HPM... (Clipsal are more durable and tend not to turn yellowish over time as compared to HPM) Any one had experience with Hagerblu wall plates? thanks! Re: Wall PLates 2Oct 18, 2010 6:36 am overly priced for what they are.... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Wall PLates 5Oct 18, 2010 12:12 pm The Clipsal vs HPM preference is akin to Holden Vs Ford. Some sparkys develop a favourite brand and often stick with them. Both HPM and Clipsal are good. Just avoid the no name clones though. Re: Wall PLates 6Oct 18, 2010 4:33 pm karbern pugs - what would you recommend to use? thanks Clipsal... I predomintly use Clipsal but do use HPM if need be... at the end fo the day I use what the Cleint tells me to use.. as it is their House..... then you need to settle on a Range with the Brand... Personally I like the Clispal C2000 range with the ID windows... but that is me... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Wall PLates 7Oct 18, 2010 8:06 pm where can I get one blank wall plate? The box is in the set plaster but there is a box shaped hole in the plaster. Since this is currently connect to a conduit that is not in use I want to block it off. Re: Wall PLates 9Oct 18, 2010 9:47 pm kexkez where can I get one blank wall plate? The box is in the set plaster but there is a box shaped hole in the plaster. Since this is currently connect to a conduit that is not in use I want to block it off. any electrical wholesaler shoudl have them in stock (if it isn't some special order jobbie) Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Wall PLates 10Oct 18, 2010 9:48 pm Olga1 Hi! Could you please advise where is good place in Sydney to have a look Crispal or another good brand? Thanks Sydney is pretty much a HPM town.. lol but any good sparky wholesaler shoudl have a display board up.. maybe see if clipsal/ hpm don't have a dispaly center close by. try these guys Turks http://www.jrt.com.au/ Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5099 I am saying that double brick has similar thermal performance due to thermal mass effect. It will be still very interesting to see the state of your framing after 10-15… 10 29659 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16043 |
