I've heard from several electricians that they prefer Clipsal wall plates to HPM... (Clipsal are more durable and tend not to turn yellowish over time as compared to HPM)
Any one had experience with Hagerblu wall plates?
thanks!
Browse Forums Home Theatre & Automation Re: Wall PLates 2Oct 18, 2010 6:36 am Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Wall PLates 6Oct 18, 2010 4:33 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Wall PLates 9Oct 18, 2010 9:47 pm kexkez where can I get one blank wall plate? The box is in the set plaster but there is a box shaped hole in the plaster. Since this is currently connect to a conduit that is not in use I want to block it off. any electrical wholesaler shoudl have them in stock (if it isn't some special order jobbie) Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Wall PLates 10Oct 18, 2010 9:48 pm Olga1 Hi! Could you please advise where is good place in Sydney to have a look Crispal or another good brand? Thanks Sydney is pretty much a HPM town.. lol but any good sparky wholesaler shoudl have a display board up.. maybe see if clipsal/ hpm don't have a dispaly center close by. try these guys Turks http://www.jrt.com.au/ Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5179 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16141 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6901 |
