Browse Forums Home Theatre & Automation Re: Easier telephone/ADSL cabling options 2Oct 04, 2010 11:26 am Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Easier telephone/ADSL cabling options 4Oct 05, 2010 12:18 am Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Easier telephone/ADSL cabling options 6Oct 05, 2010 12:48 am Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Easier telephone/ADSL cabling options 8Oct 05, 2010 12:59 am Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Easier telephone/ADSL cabling options 9Oct 06, 2010 1:11 pm Thanks for the info. I'll get my installer to use CAT6 for ALL the cabling - it's just two points for the phone - and obviously for all the data points. Thanks again. Thanks for the reply. Had a look at the suggested lot and found other problem on easement, which i will asked in separate thread. 2 17559 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12078 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6469 |
