Browse Forums Home Theatre & Automation Re: Help Please 4Sep 13, 2010 11:25 am Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Help Please 7Sep 14, 2010 10:38 am seals So whatever type of cable that ipod dock has on it I just need a double adapter and then a long enough length of the same cable to get from the room amp 1 to the room amp 2. Yes. Like I said, there may be a detectable drop in the signal strength, or there may not. It is only iPod so I guess the fidelity is not that critical anyway ... If there is a detectable drop in the signal strength and you want to resolve/improve that then you will need a dist. amp. They are not that much though - something like this unless there is something with less 'zones' and costs less $$ : http://www.radioparts.com.au/ProdView.a ... +AMPLIFIER Thankyou so much π I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK π 2 7148 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12719 All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 8203 |
