Browse Forums Home Theatre & Automation Re: Overkill 10Aug 26, 2010 5:41 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Overkill 12Aug 31, 2010 2:36 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Overkill 14Sep 18, 2010 12:49 pm [quote="joeygbh Even if he wouldn't need separate networks, I do advocate the use of multiple data points in each room. It may just be my house, but I'm beginning to see more than one device requiring a data point in each room, and thinking back it would have been for effective in the long run to have multiple lines to each room (capable of separating into different networks) than having to run multiple switches that I do now. So for all the runs you have now and think you will need, I would double it for a start.[/quote] the way his "plan" has it was seperete for each "sub net" not just a "normal" lan set up... i did state that having extra points was a good idea the way he drew it up was overly complex Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal |
