Browse Forums Home Theatre & Automation 1 Aug 25, 2010 12:02 am I'm wanting to have one of my TV's installed in our bedroom - preferably directly in front of our bed. The problem is the wall in front is single brick and has the ensuite on the other side of the wall. I'm thinking of having it ceiling mounted with something like this; http://www.justmonitors.com.au/mounttel ... gmount.htm I'm just a bit stumped - that particular product has internal cabling - ie you can put your cable through the middle of the mount, much neater etc, so i assume the power cable goes into the roof, but how? The mount would have to be bolted to a beam through the plaster, so how does the power cable get through? I realise I would need an electrician, and I plan on having it professionaly installed, but I just want to know if its going to be a big job and how it will work before i commit to it. Any ideas/advice anyone? Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72342 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2454 |
