Browse Forums Home Theatre & Automation 1 Nov 02, 2007 3:28 pm Matt,Rod and whoever else,
On a recent post you were talking about a multi-room system with independent audio zones. What technology did you use to set it all up? Is it audio only or can it handle multiple (independent) video as well? Is the system set up for expansion e.g. adding lighting or curtain controls later, more zones etc.? After 2 false starts, a year living overseas, two more world trips and 3 years of uncertainty we are now starting the build process again - hopefully for real this time! Re: Multi-room systems 2Nov 03, 2007 9:47 am Hi Muzz.
Our main brand for Multi-Room audio and video is Elan Home Systems, made in the U.S.: http://www.elanhomesystems.com/ Top quality gear (I'm even using a pair of the MP800W and a pair of the MP650W in-walls as fronts in my cinema). As for other areas: Lighting: IR light switches you can simply replace your existing light switches with are not too hard to come by. We use a couple of different types when asked, and a sparky (or you ![]() Curtains: We've never had much call for that so haven't looked into it very much. Looked into motorised blinds (internal) a while ago - looking at (very roughly) about $1K per standard/average window. Re: Multi-room systems 3Apr 12, 2008 12:47 am Hi Rodd,
does the Elan system use component video or just the RCA plugs like Starserve unit? Plan on getting a 1080P projector for theatre room but have 1080P LCD in family room. With all our components (PS3and DVD etc)in the theatre room, would be nice to share them in the family room but with better quaiity than just RCA. What would you suggest? How many different zones/rooms can it handle? What kind of costs are we looking at also? Re: Multi-room systems 4Apr 12, 2008 11:05 am Hi JT.
If you want to distribute audio and video to more than 2 rooms/zones then that's were a proper multi-room system comes into play, but if you're only talking about 2 rooms or more to the point 2 displays then you can do all of that with one A/V Receiver. Many of today's A/V Receivers that are above the entry level support more than 1 video output in Component video and even HDMI (the Marantz SR-7002 has 4 HDMI inputs and 2 outputs, and up-converts all video to HDMI). If you are yet to purchase your A/V Receiver for this theatre then getting one like this will make this very easy. If you really want to distribute high quality video and audio to more than just a second room then you need to look at a decent audio/video distribution solution. And yes, Elan Home systems do this, but you can get more affordable solutions using other componenets from other brands as well... (my own A/V Receiver is pre-HDMI and only has 1 Component video out, but I have a powered video distribution amp that can distribute Component video (and analogue audio) to 4 rooms, and these are only a few hundred dollars these days...). Home Theatre & Automation 5Sep 25, 2008 10:18 pm I have installed an advance multi room audio system in my home this stems will allow me to change sources. I could have the CD Changer playing in the kitchen and the XM radio playing in the bedroom. And when the system is playing the music very loud, but when the phone rings the music will automatically mute.and it has many advanced features.
Resource- Advance Multi Room Audio System Cheers James James Nicholes Re: Multi-room systems 6Sep 26, 2008 1:33 pm I've found the Elan Home Systems stuff to be about the best value once you get into genuine multi-room audio/video territory (at least 2 different sources available and controllable from at least 2 different rooms...), even than the NuVo stuff on that U.S. web site mentioned above, and I've tried looking into a few of the 'cheaper' alternatives but they don't offer what the Elan stuff offers (and some of what they don't offer is stuff that 'makes or breaks' the solution as a whole...). Re: Multi-room systems 7Sep 27, 2008 10:27 pm Does anyone have any thoughts on the use of network media players as an alternative for distributing media throughout a house?
I've been doing a bit of research and it seems like this could actually be a better, more cost effective option. Only requires a reliable network (wireless is becoming increasingly effective) and no need for other cabling. Then you can basically just set up a single server with all your media on it...and you can access it anywhere the network is available... A number of devices have dual hd-tv tuners built in, along with a harddrive...so you've solved your tv/pvr problem...and a few even access internet services, so u can stream them directly through your network... Anyway...it just seems like a smarter way to do things than trying to distribute different media in different ways!! Re: Multi-room systems 8Sep 28, 2008 2:34 am I'm going to have a go at rolling my own home automation system when I eventually build. Basic design is have a main server with a couple of HDTV cards (just for recording), and a NAS drive (basically a hard-drive that hooks straight into a network) to hold all my movies/music. Then have micro-PC's in each room serving as end-points that existing TV's and amps (and lights/curtains/whatever) plug into. After 2 false starts, a year living overseas, two more world trips and 3 years of uncertainty we are now starting the build process again - hopefully for real this time! Re: Multi-room systems 9Sep 28, 2008 2:37 am Sorry just realised I didn't really answer your question... ![]() If you want to just distribute media then it is quite a cost effective solution - you don't need any special cabling, and you can get sound and video cards now with 7.1 and HDMI for blu-ray etc. There's a few ways to do it - just make sure that the software you use can handle multiple 'end points' and also make sure that you can play the same song/movie on multiple TV's or rooms at the same time... After 2 false starts, a year living overseas, two more world trips and 3 years of uncertainty we are now starting the build process again - hopefully for real this time! Re: Multi-room systems 10Sep 28, 2008 8:19 am You say smarter and more cost effective - I say it's an alternative, and a good one, but not necessarily smarter and cheaper. Remember, you're talking about needing a device (media player, media PC, media extender, etc.) to play this media in every location (or at least for every location), whereas the 'multi-room' concept is more about central components doing the work and distributing the result via wire to the rooms' screens etc. Re: Multi-room systems 11Sep 28, 2008 1:16 pm Yeh, i guess the thing that gets me about the multi-room system, as opposed to have independent 'clients' in each location is that you seem to only be distributing the media, as opposed to having full control at each location...also, I like the concept of having an all-in-one device in a room - one box that does everything...
I agree that the idea of central components is great, but in that scenario, you still need other devices in a location to get the same functionality... cost wise, i'm not really across what a comprehensive multi-room system would cost...but i've got a feeling, for it to do everything i'd want...i'd be up for an arm and a leg! anyway...like you said, it's an alternative, just have to try and find what works best for your particular needs i guess! Old Home Restoration / Renovation Hi All, I am planning to convert my theatre room to 4th bed, is it worth or can we do it with the plan I have attached Thanks for taking your time Regards, Harry 0 1656 consider a rectangular table that can be extended when you have guests and pushed against the wall if you need more walking space between table and island 1 1404 Not for everyone, but have you considdered putting it above the fireplace. 1 2234 |
