Browse Forums Home Theatre & Automation Media Portal 10Nov 06, 2007 9:47 am I have been using media portal for over 3 years now with a microsoft media remote. Its close to perfect for having a simple pc running a HTPC solution.
Media centre can run on low as well as high end computers, you can make it run at startup so that when you boot the pc it starts straight away. There are some limitations like any other software particularly with TV recording and the like but for a simple to use system with a remote control it is very good and free!!! The vista solution is very power hungry, hence you need a better pc, result is more noise and heat. We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16275 From what I know about water tanks (I've been working with a client on them for a few years now) is this - The concrete can last a lifetime if they don't crack for some… 2 10629 |
