Browse Forums Home Theatre & Automation Re: HDMI extension with wall plate 2Jul 04, 2010 6:30 pm Check out www.monoprice.com I brought all my cables off them and they are brilliant and super cheap! Check the item you're after and usually there is a heap of feedback from customers for each item. Our house thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=18335 Re: HDMI extension with wall plate 3Jul 06, 2010 1:30 am Clipsal now make some nice HDMI adaptor for their wall plates. One is straight through the other goes at 90' in the wall. The theory being you buy two of these and put a patch cable in the wall to join the two. Straight version http://updates.clipsal.com/ClipsalOnlin ... HDMIS&ref= 90' version. http://updates.clipsal.com/ClipsalOnlin ... HDMIA&ref= They also have some new snazzy looking plates for home theatre etc as seen in this brouchre. http://www.clipsal.com/trade/__data/pag ... 000080.pdf As for adpators to change HDMI to CAT6, myself I have never been a big fan of these kind of things as often quality gets compomised, so kind of defeats the purpose of using something like HDMI in the first place. So the answer is always to do it right, even if it does cost. Re: HDMI extension with wall plate 4Jul 06, 2010 10:49 am I have had some personal experience with these things and so far am not happy with them (basically I ran two lengths of Cat5E (yes, they are supposed to work with Cat5E, not just Cat6) and used 3 different types of these things and simply could not get it to work). I think the first rule is if the 2 lengths of cable are not EXACTLY the same length (and I mean to the cm) the you could have potential problems. Might also be an argument to not try it with Cat5E in future... Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8488 Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5465 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6156 |
