Browse Forums Home Theatre & Automation 1 Jun 22, 2010 2:00 pm Hi all, Im building a new home and currently getting electrical wiring as well as other cabling put in the house. I am not sure if I can take advantage of running speaker cabling in the walls to hide the cables in my living room as it is a 'open' area. I have attached a sketch image of my living room layout in which I have indicated the rough furniture lay out and the possible speaker locations (pink) (speakers will be on stands and not wall or ceiling mounted). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Worse comes to worse ill get a rug later on and run the cables underneath it. Any recommendations is very much appreciated! Re: Audio cabling recommendation for open living room 2Jun 24, 2010 11:24 am Don't know what you're gunna do there mate - I'd be using In-ceilings for the 2 surrounds. The front 3 speakers should be easy no matter what you do as they at least back onto a wall... Re: Audio cabling recommendation for open living room 3Jul 09, 2010 12:49 pm Looks like a really similar lay out to mine and yeah, same problem as mine What's worse is that I missed my chance to put the speaker cable in before the plaster went up so I'll be painting the cables and running it against skirting I think. If you don't go the in ceiling speakers, speaker stands don't look too bad. If not behind the couch, you can wire speaker points to the corners of that open space area (the corner near that sliding door and on the opposite side) and then go either ceiling mounted from those points or cleverly disguised speakers. As I said I've got the same problem and I think I'm going to just suck it up with trying to find really cool looking speaker stands. Speaking of, you know of any Rodda? Re: Audio cabling recommendation for open living room 4Jul 10, 2010 7:15 pm Selby Acoustics actually have some reasonable options: http://www.selbyacoustics.com.au/StoreF ... 20&c=84148 I actually used a pair of the 1200mm ones a while ago for the pair of Paradigm Atom Monitors that Vanderlay has as surround speakers in his Cinema - very good. Hello! We have a very large open plan living room and wanted to get layout options, and furnishing ideas for this space. Currently there is only a… 0 9327 sorry mate, not wasting more time on this. Youve completely missed the mark on some fundamentals and regardless of how many times i try and put it to you differently, you… 11 9187 1 is free to air and the other 2 are for cable TV all of them completely useless in 2024 1 2262 |
