Browse Forums Home Theatre & Automation Re: HT room size 2Jun 04, 2010 10:33 am artnik Hi guys new to this forum, looking at turning a room into dedicated HT room but size is only 4.6m x 3.5m. Is this room sufficient and what size screens would you recommend You forgot to mention which axis you are viewing from and any furniture you may have that will decrease the length of it. Re: HT room size 4Jun 04, 2010 1:07 pm artnik i'll be using it as the 4.6m being my length and will squeeze 4 recliners down one end Should be ok for a typical 100-110" diagonal screen in a 16:9 format to get full benefits of a 1080 projector. I have one similarly sized screen at 3.9m using a 1080 projector. Any smaller and you will lose the 1080 benefits. The others on here will confirm. Re: HT room size 5Jun 04, 2010 7:22 pm I concur with Joey - 100-110" 16:9 screen will be good in there if you are sitting more than 4m away from the screen. Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7490 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3657 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3544 |
