Browse Forums Home Theatre & Automation 1 May 18, 2010 1:49 pm Hi all, We forgot to add a junction box to the Home theatre room with the builder. So all we have now is a light bayonet in the centre of the room that can be controlled by a dimmer switch which we have included. What are our lighting options now? Can a sparky still install downlights??? What I would ideally like is for our dimmer switch to control about 4 - 6 downlights...is this possile without tooo much work for a sparky? If not, then what other types of lights can we install 'easily' thru a sparky??? Thanks Sara Building with Celebration homes SOR Perth [color=#BF00BF] Re: Home theatre lighting options 2May 18, 2010 1:56 pm would be fairly easy as it is a single storey building .. downb lights offer the best for "mood" lighting on a coupel fo circuits aswell so you can control the mood.. Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Home theatre lighting options 3May 18, 2010 8:53 pm in our old house, we had a single light in the centre of the dining room, we changed that to a downlight and added 4 more lights around it - imagine 4 lights in a rectangle, with one in the centre. Did it that way so we wouldn't have to replaster & repaint the ceiling. In the HT we're building the builder is putting 3 lights down the centre, we'll add another 3 on either side for a total of 9 on 2 different dimmer switches. T&T Knockdown and rebuild - building Metr1con Nolan 41 (43) @ http://tim-and-tina.blogspot.com! http://www.verdantdental.com.au Re: Home theatre lighting options 6Jun 02, 2010 11:15 am I am looking into what would suit my dedicated home theatre room best with lighting. I'm trying to steer away from downlights due to being inefficient and essentially just holes in the ceiling to wall lights on the sides that shoot up against the wall. I'm thinking two on each side and possibly two either side of the screen - all on dimmers of course. Possibly have them automated as well with different scenes. Builder: Dennis Family Homes House: Hartley Facade: Provincial Suburb: Lyndhurst Moved in! http://cynash.blogspot.com Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28804 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8770 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8549 |
