Browse Forums Home Theatre & Automation 1 May 04, 2010 11:00 pm What do I need to future proof it? I have plenty of cat 6 cable, rg6 coax, figure 8 cable, and all sorts. Alternatively should I just have a 50mm conduit all the way to the roof space until Its worked out just exactly what I need? Re: Building and want to have a nice viewing and listening r 2May 05, 2010 12:39 am Fluidtron What do I need to future proof it? I have plenty of cat 6 cable, rg6 coax, figure 8 cable, and all sorts. Alternatively should I just have a 50mm conduit all the way to the roof space until Its worked out just exactly what I need? no need for conduit if you have "straight" drilled holes going to each area you may want to improve later on, as long as it si single story house but if it is two story and then maybe conduits with pul ropes but if you put enough cable in to start with.... other then upping to cat6a and at $3.60/m compared to around $1/m it is up to you.... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Building and want to have a nice viewing and listening r 3May 05, 2010 6:52 am It is a 2 storey house. The location I want the cabling to go to is on an exterior wall, however this exterior wall tucks in about 3-4 metres on the second level. What cabling do you think is required? I would be wary. Is you site demilished but nothing else done? Sounds like liquidity problems to me. Our builder did the same. Got hundreds of thousands of dollars of… 2 15392 Sounds like rubbish to me. Ask for the contamination report which I doubt they have. If it's part of a normal subdivision it would have had a contamination report done… 9 5645 You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18063 |
