Browse Forums Home Theatre & Automation 1 Apr 30, 2010 8:18 am http://users.tpg.com.au/nklobouc//Nathan_Data_Plan.png Hello Gents (ladies if you exist here), Can I get some advice please on my home network. Please click on the link to see the pic, sorry for the size and I have not bothered to re-size it. At this stage it is just a cable diagram, I need to get this laid out and finalised so I can give the sparkies the diagram (which will look different btw, just showing the room name and what needs to goto it from the study wardrobe). It also does not show direction of traffic, what items are to be used and how. We just need to future proof the house so that I wont need to go digging around in the roof and walls in a few years time. Is this a suitable mock up of what I will need? Will I need any more points in the rooms? Is the cable type CAT6? Some other info: My phones are cordless and run from a base station ( http://www.uniden.com.au/AUSTRALIA/p_el ... _index.asp ) so no phone outlet needed apart from in the study. Bosch 16Plus Security System also to be installed. If you can help me out this would be appreciated. Re: Cable Diagram Needing Advice 2Apr 30, 2010 8:21 am as long as you have more then one data run it is future proofed ie room for expansion Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Cable Diagram Needing Advice 3Apr 30, 2010 8:26 am Cheers Pugs! I'll trim the crap from that plan and have a chat to the blokes. Re: Cable Diagram Needing Advice 4Apr 30, 2010 8:42 am and yeah Cat6 ftw.. Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17665 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13833 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6901 |
