Browse Forums Home Theatre & Automation Re: Home Theatre Setup 21Oct 05, 2007 9:21 am Sorry Lee, I should have remembered you had that amp. It is a 6.1 so the 3 surround speakers are correct!
Now, according to it's specs it does A + B speakers, but also has a couple of other (multi) zones you can use. These will be line-out/pre-out outputs so you will actually need some other type of amp (each) for those zones (a simple stereo amp will suffice, or dedicated stereo power amp). This setup tends to lift the level of complication a little. You might find it easier and cheaper to get the speaker selector like above and run from your Speaker B outputs into it, then it will be able to service up to 4 other rooms (besides your theatre). Old Home Restoration / Renovation Hi All, I am planning to convert my theatre room to 4th bed, is it worth or can we do it with the plan I have attached Thanks for taking your time Regards, Harry 0 1798 IsnJ Sorry to hear the predicament you are in. If you haven't done so already I would jump on the phone this morning to ICare as they should be able to walk you through… 1 4159 ![]() They all seem to be rendered over like this. It’s a bevel build. We are getting a dilapidation report however they are coming out tomorrow after the demolition has… 3 6432 |
