Are there any real differences between a $40 cable and a $180 cable?
I'm looking at a 10 meter cable and dont want to lose quality due to a crappy cable, but nor do I want to be screwed either.
Thanks,
Browse Forums Home Theatre & Automation Re: HDMI Cables 4Apr 14, 2010 3:21 pm ---------------------------------------- Building the PD Lisbon 24 http://www.porterdavis.com.au/#homeviewer/lisbon/24 Blog of our progress. http://lisbon24.blogspot.com/ Homeone build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=28665 Re: HDMI Cables 5Apr 14, 2010 5:47 pm Blog: http://funmore-residence.blogspot.com/ Forum: viewtopic.php?f=31&t=21109 Construction Start - 19/09/09 Slab Poured - 21/10/09 Frame Completed - 25/11/09 Lockup - 22/12/09 Fixing - 22/02/10 Handover & Moved In 30/04/2010 Re: HDMI Cables 7Apr 15, 2010 3:35 pm ---------------------------------------- Building the PD Lisbon 24 http://www.porterdavis.com.au/#homeviewer/lisbon/24 Blog of our progress. http://lisbon24.blogspot.com/ Homeone build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=28665 Re: HDMI Cables 8Apr 15, 2010 5:26 pm Blog: http://funmore-residence.blogspot.com/ Forum: viewtopic.php?f=31&t=21109 Construction Start - 19/09/09 Slab Poured - 21/10/09 Frame Completed - 25/11/09 Lockup - 22/12/09 Fixing - 22/02/10 Handover & Moved In 30/04/2010 Re: HDMI Cables 9Apr 15, 2010 5:52 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: HDMI Cables 18Oct 29, 2010 7:03 pm Rodda There is defnitely some difference in quality - I've had bad experiences with really cheap HDMI cables (basically just not working) like the ones that sometimes get bundled with some gear (cheaper Blu-Ray players for example). As soon as I swapped the cable for a Selby one (P.S. Ugly=Selby) - which in my opinion are also still very affordable compared to big brands like Monster, the problem was fixed straight away with the Selby cable. A 10m HDMI cable for $30 is cheap cheap - I personally wouldn't trust it... I'd suggest the cheap HDMI are not HDMI certified and are probably made in China or similar intellectual property/standards ignorant country. They may carry the term, but from China that doesn't mean much. |
