Browse Forums Home Theatre & Automation 1 Mar 04, 2010 11:05 pm Sorry, but I have been out of the industry for a little while and can't remember the legalities behind it all. I hold a current ticket that has not expired and I am registered with BICSI cablers. Now I know that I am able to my own Networking cabling in my house and plan to run cat 6 everywhere, however does the job actually have to be signed off by a "company" with an ABN etc, Or can I just do the job? Re: Can I legally cable up my own home? 3Mar 04, 2010 11:37 pm Fu Manchu No YES HE Can Legally... weather he has the actual "installtion" knowledge then that is a different discusion all together... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Can I legally cable up my own home? 4Mar 04, 2010 11:51 pm Pugs Fu Manchu No YES HE Can Legally... weather he has the actual "installtion" knowledge then that is a different discusion all together... Yes, but is that enough, does it not need to be signed off from a "company"? Re: Can I legally cable up my own home? 5Mar 05, 2010 12:02 am Jimako Pugs Fu Manchu No YES HE Can Legally... weather he has the actual "installtion" knowledge then that is a different discusion all together... Yes, but is that enough, does it not need to be signed off from a "company"? Answer sent via PM... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Can I legally cable up my own home? 6Mar 05, 2010 12:18 am some guy *any posts are not to encourage DIY Cabling I'll stick to Landscapes and plants Re: Can I legally cable up my own home? 7Mar 05, 2010 12:23 am Fu Manchu some guy *any posts are not to encourage DIY Cabling I'll stick to Landscapes and plants you do that.. Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Can I legally cable up my own home? 9Apr 03, 2010 7:17 pm Pugs Jimako Yes, but is that enough, does it not need to be signed off from a "company"? Answer sent via PM... Don't suppose you can share the answer to this question with the wider audience? Re: Can I legally cable up my own home? 10Apr 03, 2010 10:31 pm Sheepdog Pugs Jimako Yes, but is that enough, does it not need to be signed off from a "company"? Answer sent via PM... Don't suppose you can share the answer to this question with the wider audience? The OP is a Licensed cabler .. but it isn't his main work thus he is able to the do the work and i gave him the info to ensure he is covered legally if ever needed to cough up the paper work to do with the cabling. other reasons i don't give out diy adivce is i coud be sued over fualty work someone else has done.... even having the right insurance wouldn't cover me... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Can I legally cable up my own home? 12Apr 06, 2010 3:59 pm Flukey What cabling is he not allowed to install? 240V I can understand. What about speaker cables? And what is the issue with Cat6? Mains and anything connected to mains you understand, speaker wire is also okay. I think the rule is any permanently installed cable with the potential to be connected to the communications system (telstra copper) must be installed by a qualified technician. So Cat5/6 ****** on the floor is ok. Cat5/6 through a wall is not. Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20417 I have a home gym at home. It weights 150KG including the weight stack. I'm a big boy, around 150KG myself. I was thinking about moving it up stairs to the second… 0 6305 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16280 |
