Browse Forums Home Theatre & Automation 1 Feb 08, 2010 10:24 pm Dear Rod & Everyone I am new to the Forum - Just waiting for DA to come through before we make a start on our new home. I want to do a basic automation within 3 rooms 1 X Theatre 1 x Living 1 x Bedroom 1 What I would really like to do is have all AV Equipment in the Theatre room and wire to other Tvs in the house. I want to work with the equipment I have and some of the equipment i am considering buying. Some of the stuff is a few years old and this may hold us back. I really am looking for advice on what I need to purchase or request of my builders sparky. Builder is helpful and is happy for us to do whats required at frame stage. I will work through the rooms 1 by 1. Home Theatre 1 x Wall Mounted Sony KDL46WE5 LCD HD TV (4 x HDMI) 1 X Sony Receiver/Amp Model STR DB795 5.1 (NO HDMI) 1 X Sony Bluray S360 (HDMI) 1 X Sony Hardisk/DVD Model RDRHX710 (NO HDMI) 1 X Sony Digital Box Model DST HD500 (HDMI) 1 X Sony Ps2 Slim (No HDMI) 1 X Sony Speakers Floor Standing with Subwoofer Things under consideration TIVO Sony Ps3 Objective = Wall mount LCD with Power and Multiple 4 x HDMI Cables (in wall) Speaker Cable in wall to corners and wall plates installed for easy connection of speakers. Centre speaker wall hung DVD/HARDISK + BLURAY Connected to LCD in theatre + Plasma Panel in Living = LCD in Bedroom 1 If TIVO is purchased Connection to Plasma in Living + LCD in bedroom 1 is required. PS2 Connection to LCD In theatre. Bedroom 1 1 X Wall Mounted Sony KDL22S5700 LCD TV (HDMI) Objective = Wall Mount LCD With power Have connection/feed for picture and sound from DVD/HARD DISK + BLURAY + POSSIBLY TIVO to Bedroom 1 LCD Living 1 X Wall Mounted Sony PFM42V1 42 INCH PLASMA PANEL (NO BUILT IN TURNER) (NO HDMI) Speakers Connected (Mount on plasma) Main cable VGA @ Panel to RGB Objective = Use Plasma Panel In Living area with HD BOX/DVD/BLURAY and maybe TIVO signal from Theatre room. Wall plate at floor level to enable connection on PS2/PS3 from time to time. Remote Control IR Remote to enable DVD/BLURAY + + to be used/controlled from other rooms. Thanks in advance for any help you can give to set me on the right path. Cheers Marc Re: 3 Room AV Automation - What do I need Please? 2Feb 09, 2010 5:08 am did someone roll a Sony truck? Re: 3 Room AV Automation - What do I need Please? 4Feb 09, 2010 8:04 pm If you had a Sony HDMI receiver then you could use Bravia Sync? This will allow you to control your receiver through your tv with your tv remote if connected with HDMI. It is something that seems possible but I have yet to find an answer as to how effective it is. What can and cannot be controlled is not defined on the Sony web site, and I can see that not EVERY possibility could be covered, but I am unsure. If someone has this feature I would love to know their experience. Slab poured 21/04/2011 Frame finished 27/05/2011 Moved in 07/11/2011 Re: 3 Room AV Automation - What do I need Please? 5Feb 10, 2010 9:33 am Thanks Mate Just the LCD and Blu ray are Bravia Sync I think. More worried about connecting the Plasma to DVD/Blu ray + Digital Box in the other room. Thats an answer I hope to get. Re: 3 Room AV Automation - What do I need Please? 6May 06, 2010 12:52 pm Use a 4 x 4 matrix splitter over cat5e/6 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28812 Thank you @. Tried to play with the facade models but the exact colour is not matching up. 2 3260 Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4709 |
