Browse Forums Home Theatre & Automation 1 Feb 05, 2010 12:33 pm Hi Everyone, This is my first post here, and I kind of feel bad to start with a question instead of a tip or an advise to someone I’m building a new house and would like to smart wire the house myself and make it a future proof as possible as I don’t tend to move out of it (I hope so). I’m undertaking a restricted registration course from JB Hunter Technology and applying for a license from TITAB Australia Cabler Registry Services. I have knowledge about all different cable types, connections, video and audio formats. But my weak points are in design ideas. My first question is do I really need to consider feeding every room/location with an HD signal in mind? Wouldn’t it be cheaper if I purchase the HD player and place it in the room instead of running two cat5e cables and using two baluns? Or is it for things like outdoor TV or HD Foxtel? Thanks in advance. Riado Re: I'm confident of doing it, but need ideas please 2Feb 05, 2010 1:21 pm My basic spec for any hosue is: Bedrooms 1 x RG6 and 2 x Cat6, TV / HT areas 2 x RG6 and 4 x Cat6 + speaker wiring. sending HD signals via HMDI gets exepnsive very quickly where as a simple HD (via ethernet) play back device is cheaper in the long run and esp with mulitply units and having a single HFS streaming all the media Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: I'm confident of doing it, but need ideas please 3Feb 05, 2010 2:35 pm So you mean sending component HD signal instead of HDMI via single cat6? But you are left with only 1 pair, how would you transmit the stereo signal then? Or you mean a media centre system, and clients accessing via IP. If you mean the former, then the answer would be no need for HDMI, right? Re: I'm confident of doing it, but need ideas please 4Feb 05, 2010 2:49 pm riado So you mean sending component HD signal instead of HDMI via single cat6? But you are left with only 1 pair, how would you transmit the stereo signal then? Or you mean a media centre system, and clients accessing via IP. If you mean the former, then the answer would be no need for HDMI, right? yeah later ftw.. is how most geek hoses do it.... media center HFS same thing really.. se *** up with a coupel of tuner cards then you will be set for recoridn all your favourite shows Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: I'm confident of doing it, but need ideas please 5Feb 05, 2010 4:12 pm Very good At this stage (running the cables) I don't need to worry about what equipment I need to install in the enclosure (I can do it first thing after I move into the house). But I think I need to worry about what type of enclosure and how I place the big bunch of cables in that area. I mean do I need to install the enclosure so I allocate extra studs for it? Do I tight all cables together and leave behind the plaster wall? I really appreciate your time in this Re: I'm confident of doing it, but need ideas please 6Feb 05, 2010 4:26 pm call me .. Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal The DIY project can be broken into two major steps. Planning and Design and Construction. Both of these steps are as important as one another to ensure you give… 0 5149 Hi group, have some damage to the door frame and skirting board. It's a side door to the laundry area. Only has a security door. I had a termite inspection (note drill… 0 5050 0 1967 |
