Browse Forums Home Theatre & Automation 1 Oct 29, 2009 7:32 pm In the new house I am building, I am not sure if I will be taking my existing theatre, or buying a new one. My current theatre is high def (only 768, not 1080 but still looks sweet) and everything is run through HDMI. I installed it a few years ago now, and forgotten most of the stuff to look for. Should I pre wire the new house keeping in mind future upgrades I may have - everything from amp, projector and speakers - if I was to sell my theatre with my current home. Has anything changed with regards to amps, cables, etc. Should I just pre wire the theatre room with decent speaker cable and hdmi, and will it make a difference if I re-use my existing theatre set up or buy a new one ? Blog is now up - http://www.jbdave.blogspot.com/ Re: What to do with the new theatre 2Oct 30, 2009 3:59 pm You should pre-wire when/where ever you can. You should run 5 if not 7 speaker wires from where you plan on keeping your AV Receiver to where you will want your speakers to be, and don't forget to run a subwoofer cable (single RCA terminated coax). Also, the subwoofer needs power so make sure there will be a power point near the sub (the sub can go anywhere in the room). Run a HDMI cable from where the AV Receiver will be to where your display device will be (flat panel TV or projector). If the place is single storey then you will be able to change or add things later without too much extra trouble. The features being offered in AV Receivers grows/changes every year so do some research online, whereas speakers don't really change at all... Re: What to do with the new theatre 3Oct 30, 2009 4:14 pm Rodda You should run 5 if not 7 speaker wires from where you plan on keeping your AV Receiver to where you will want your speakers to be I'd consider doing 2x speaker cable runs to each position. Speaker cable is cheap enough that building in redundancy is worth considering. Re: What to do with the new theatre 4Oct 31, 2009 9:41 am Thudd Rodda You should run 5 if not 7 speaker wires from where you plan on keeping your AV Receiver to where you will want your speakers to be I'd consider doing 2x speaker cable runs to each position. Speaker cable is cheap enough that building in redundancy is worth considering. I understand the idea of redundancy, but I'm confused as to what benefit 2 runs of speaker cable can have, either for the near or distant future?? (unless you think there's a chance one of your speaker cables will get severed somehow...). Re: What to do with the new theatre 5Oct 31, 2009 1:56 pm Agreed pre wire when can and agreed single story home would not be a Big issue here, in my opinion and thinking of upgrade in future then one set of decent speaker cable is needed.. longer the run of cable thinner the guage of wire in normally used and if you need to splice the cable re connecting two wires for a longer run then the splice is preferred to be in the house and not in the roof.. Re: What to do with the new theatre 6Nov 05, 2009 12:31 pm Thanks for the replies. What size speaker cable should I run ? At the moment, I have some thick speaker cable, but don't know it's size (it was supplied when I bought the speakers). Blog is now up - http://www.jbdave.blogspot.com/ Re: What to do with the new theatre 7Nov 05, 2009 1:10 pm 12 AWG speaker cable is probably priced about right (somewhere around $2-$3 per metre). 10 AWG is about twice the price - and some equipment (AV Receivers) will not have binding posts that will easily accept it [so check that first]. Try Selby's online (I have no affiliation, just used them before and had great products and great service) ... avoid franchise electronics/electrical stores. Re: What to do with the new theatre 8Nov 05, 2009 3:55 pm jbdave Should I just pre wire the theatre room with decent speaker cable and hdmi, and will it make a difference if I re-use my existing theatre set up or buy a new one ? if you are happy with the sound and picture i wouldnt change it. i dont even have hdmi as audio, still using optical as my pre/avr does not support hdmi. i am in no rush to change this as i am more than happy with the sound i am getting. A person needs to be licensed to offer financial advice. Surely the accountant you use would have been chosen for his/her expertise in this field. Have you asked your… 1 6737 Is there a building permit? RU in Victoria? What is the value of the building contract? 1 6831 |
