I am after one that can be wall mounted and flat. I would like to watch movies etc on this.
Any help on what to look for would be appreciated.
Thanks
Browse Forums Home Theatre & Automation 1 Jun 19, 2007 12:46 pm I have absolutely no idea ![]() I am after one that can be wall mounted and flat. I would like to watch movies etc on this. Any help on what to look for would be appreciated. Thanks ![]() Re: Bedroom Wall Telly 4Jun 19, 2007 1:59 pm I would suggest a 68cm widescreen lcd (26") with a wall mount bracket.
The antenna could be connected from inside the wall and the power cable run inside the wall to a power point located away from the set. Should be able to do tis for under $1000 if you shop around... Re: Bedroom Wall Telly 5Jun 19, 2007 2:20 pm Just make sure you are happy with the size if going for the 68cm widescreen. Widescreen (16:9) looks much smaller against equivalent normal screen (4:3). Try to get the 2 ratios side by side to know what to expect. It is hard to jdge sizes in the shop due to the lack of reference points that you would normally have in your home.
3xb Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 2504 Hi, I'm planning to build a new house and wanted to get some feedback on the different window designs for a master bedroom. Our bedroom is north facing and the bed will… 0 2499 1 10390 ![]() |
