Ok, so the electrician just called and Adenbrook homes do not supply antennas.
He has given me a price of $295 including power booster (whatever that is!!)
Is this an ok price?
Browse Forums Home Theatre & Automation 1 Jun 19, 2007 8:50 am Ok, so the electrician just called and Adenbrook homes do not supply antennas.
He has given me a price of $295 including power booster (whatever that is!!) Is this an ok price? Our Adenbrook home was completed in September. Re: Antennas??? 3Jun 19, 2007 9:51 am ![]() Provided it does Digital television, it is. Standard antenna that recieves analogue TV signal well will be fine for digital. I would get very suspicious of anyone trying to sell me a "Digital TV Antenna". As for price, probably about right, about 50% to 70% for the antenna and the remainder for the install. The power booster is an amplifier that attempts to increase a weak signal. The best thing is probably to try get a portable Tv down there to test it as soon as he is done. This is not 100% because signals are affected by atmospheric conditions and can vary between day/night/winter/summer etc. Best to have a warranty to go with it. 3xb Re: Antennas??? 4Jun 19, 2007 9:56 am ![]() Standard antenna that recieves analogue TV signal well will be fine for digital. I would get very suspicious of anyone trying to sell me a "Digital TV Antenna". In my area it is actually different. The digital signal is transmitted on a different frequency range, so the spacing etc of the elements is different. It is otherwise totally normal though. One thing you probably want is RG6 quad sheilded cable and F connector (screw on) ends for a better quality connection. Some signal amps (boosters) will actually filter out the digital signal too, so certainly ask the digitial question. Re: Antennas??? 6Jun 19, 2007 11:22 am I think what Adrian is more suggesting is to make sure it's a 'combo' antenna. There is a slight difference in the way an antenna is constructed if designed for optimum analogue reception, vs the construction of one designed for optimum digital - it's in the number(s) of short and long elements and in their spacing(s), but I don't think there's much difference in it. If you get a good 'combo' it is designed to cover the biggest amount of overlap of the optimums of both signal types.
Basically, if you're in an area that noramlly has at least OK reception, a good combo antenna (I went for a fairly big one when I installed my own in my new house - a Hills OMX-400 Plus) should do the job nicely. Get some sort of assurance from your installer re it's ability to pick up digital as well as analogue, and whether or not you're considered to be in a 'fringe' area and the antenna will be good enough for your area, etc. For $295, including a power booster (pretty good idea if you plan on splitting the signal path a few times (multiple TV points) - usually installed as close to the antenna as possible so it boosts the cleanest signal possible), installed, that's a pretty good price. The installer should absolutely be using RG6 Quad Shield for all runs - it would be criminal these days to run anything less. Re: Antennas??? 7Jun 19, 2007 12:41 pm Awesome, thanks guys! I have told them to go ahead with it. It is a digital antenna, he said that thats what they are these days.
I called up Mr Antenna and their price is $250 without the power booster. Our Adenbrook home was completed in September. Re: Antennas??? 8Jun 19, 2007 1:30 pm Slightly related to this...
My builder don't do TV point, telephone point or Antenna. They recommended a communication company (called Beeman something) to do the TV point, I called them and was told they only do TV point ($80 each), telephone point ($380 for initial Telstra underground connection, $80 per telephone point after that), and data network connections ($80 each port). They don't do Antenna either. I have to find another company to do the Antenna, why they like to make our life so difficult ![]() Question is: 1) Can any one please recommend a few good companies/contractors in Sydney that can supply and install Antenna? 2) Those prices for TV point, telephone points, network point mentioned above, does that sound reasonable? If not, please kindly recommend a few good ones in Sydney. Thanks in advance! Cheers Allan http://building-our-first-house.blogspot.com/ multi 9Jun 20, 2007 1:24 am Hi aaurora
I think the booster is generally when you have more than 1 outlet. You should perhaps get a second opinion/quote. Regards Re: Antennas??? 11Jun 20, 2007 8:38 am What if the area will be using cable (e.g. for foxtel) - do I still need an antenna? The builder will connect up TV points. Re: multi 12Jun 20, 2007 6:25 pm ![]() Hi aaurora I think the booster is generally when you have more than 1 outlet. You should perhaps get a second opinion/quote. Regards We are getting two outlets, but only plan on setting the other one up when we have little ones and they want to watch cartoons ![]() I am fairly happy with the price. Meh, I'm lazy as well, and its easier for them to organise it than for me ![]() Our Adenbrook home was completed in September. |
