Browse Forums Home Theatre & Automation 1 Jun 13, 2007 9:49 pm Hi guys,
Any ideas for hiding a roof mounted projector and screen? Would be nice to not see them at all when they arent being used, but even just making them less noticable would suffice. Has anyone tried doing this before? cheers Re: Ideas for hiding projector screen. 2Jun 13, 2007 11:35 pm LP morgan have some awesome ideas in this area:
The Dipper Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The Flipper Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ and The C Lift Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I have personally used both the Dipper and C Lift and can recommend both.. http://www.lpmorgan.com.au/products/projectormounts.htm Re: Ideas for hiding projector screen. 3Jun 13, 2007 11:50 pm Re: Ideas for hiding projector screen. 4Jun 13, 2007 11:55 pm And here are some pics of my last house. I had hidden everything, speakers, projector, screen, electronics...
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sorry about all the pics.....I was really happy with this install! Re: Ideas for hiding projector screen. 5Jun 14, 2007 9:16 am Re: Ideas for hiding projector screen. 6Jun 15, 2007 12:50 pm Hi Matt/Rodda,
Can you please provide a rough figure how much those projector/screen hiding thing worth, and installation? Need to allocate some budget for that... Cheers Allan http://building-our-first-house.blogspot.com/ Re: Ideas for hiding projector screen. 7Jun 15, 2007 1:15 pm Allow around $1200 for the screen hideaway and up to $3000 for the proj. Re: Ideas for hiding projector screen. 8Jun 15, 2007 2:00 pm ![]() Allow around $1200 for the screen hideaway and up to $3000 for the proj. Thanks for the info. Does this includes the screen and projector itself, or just the cost for the hiding material/equipment and installation? I guess also need to add a few power points in the ceiling as well? Cheers Allan http://building-our-first-house.blogspot.com/ Re: Ideas for hiding projector screen. 9Jun 15, 2007 2:36 pm Other than asthetics and dust, is there any disadvantage to having it permanently mounted? I have a $100 mount that I got at the time I brought the projector. Any issues with this?
3xb Re: Ideas for hiding projector screen. 10Jun 15, 2007 2:54 pm Only thing I can think of is that hiding the screen allows you to use the room for other things.
I am actually shooting on to a black wall, and have no issues wt all, except the wife is eyeing of a Ken Duncan print...... Help Matt or Rod????? Adrian B Re: Ideas for hiding projector screen. 11Jun 15, 2007 6:47 pm ![]() ![]() Allow around $1200 for the screen hideaway and up to $3000 for the proj. Thanks for the info. Does this includes the screen and projector itself, or just the cost for the hiding material/equipment and installation? I guess also need to add a few power points in the ceiling as well? Cheers Allan http://building-our-first-house.blogspot.com/ Nope just the devices for hiding away and installation!! lol ![]() Power points are a must have if you plan on having "hideaway" devices.... Re: Ideas for hiding projector screen. 12Jun 15, 2007 6:49 pm ![]() Other than asthetics and dust, is there any disadvantage to having it permanently mounted? I have a $100 mount that I got at the time I brought the projector. Any issues with this? 3xb 3xb... None at all! Depends on what you want the room for or if you want to see the gear. In the last house (pics above) it was dual pourpose so i had to be able to hide it, in the new house it is a dedicated room so it will all be on display.. ![]() Re: Ideas for hiding projector screen. 13Jun 15, 2007 10:47 pm ![]() Nope just the devices for hiding away and installation!! lol ![]() Wow, that's a bit higher than I expected. Thanks for the information. Will need to wait and see how the construction goes first. The hide away of the screen is definitely a must have. One more question, if I install the hide away screen + projector after the house is finished, will there be big difference in the installation cost? Assuming I got all the wiring and power points done during the construction. I need to sort out the priorities based on the budget, Plasma first then the projector+screen. Cheers Allan http://building-our-first-house.blogspot.com/ Re: Ideas for hiding projector screen. 14Jun 15, 2007 10:52 pm Hide away box needs to be looked at prior to install..
I t takes up a lot of space and depending on which way your trusses run it may be easier and more structurally sound to "frame it in" before the plaster goes up! The projector hideaway is the same! If you are just mounting the proj. ot the roof then it makes no difference! You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 3163 ![]() 2 1669 How about some decorative film on the window? Will still let light in but obstruct the view of the fence 3 4876 ![]() |
