Browse Forums Home Theatre & Automation 1 Sep 08, 2009 1:14 pm can someone tell me please what is the difference between Hills home hub 600 & 1000? progress viewtopic.php?f=31&t=20401 sculptures viewtopic.php?f=36&t=26607 pole trouble viewtopic.php?f=3&t=25988 Re: Hills home hub products - what is the difference?? 3Sep 09, 2009 7:10 pm seeking solutions can someone tell me please what is the difference between Hills home hub 600 & 1000? Size. One is 600mm high and the other is 1000mm high. Re: Hills home hub products - what is the difference?? 4Sep 09, 2009 10:46 pm Djelibeybi seeking solutions can someone tell me please what is the difference between Hills home hub 600 & 1000? Size. One is 600mm high and the other is 1000mm high. the answer I got so far is one is for domestic needs and one is industrial although with all the ideas my DP has we may be looking at the industrial progress viewtopic.php?f=31&t=20401 sculptures viewtopic.php?f=36&t=26607 pole trouble viewtopic.php?f=3&t=25988 Re: Hills home hub products - what is the difference?? 5Sep 10, 2009 12:19 am one of the many reason i don't use hills hubs as soloution for my clients.. tho if someone was dead set on installing one I would give it a fair go Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Hills home hub products - what is the difference?? 6Sep 10, 2009 8:27 am Pugs one of the many reason i don't use hills hubs as soloution for my clients.. tho if someone was dead set on installing one I would give it a fair go what options are there??? progress viewtopic.php?f=31&t=20401 sculptures viewtopic.php?f=36&t=26607 pole trouble viewtopic.php?f=3&t=25988 Re: Hills home hub products - what is the difference?? 7Sep 10, 2009 10:13 am lots of them... sure they arn't as "smart looking" as a hills hub cabinet but they do the job.. anythng from amdex 9Ru 10" rack with TV, Voice and network patching and equipment inside to a full blow 27Ru 19" rack depends on how deep your pockets are Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11035 Thanks again Simeon for being so elaborate. Appreciate it. Its gives us a very idea. Kind Regards 4 3666 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16275 |
