Browse Forums Home Theatre & Automation Re: ADSL 1500KB Speed 2Sep 02, 2009 4:56 pm Rhythm Does anyone have current ADSL on 1500KB speed. How do you find this speed? You may have posted this in the wrong forum but I have 1.5mb adsl and its fine, not as quick as adsl2, but it is fine for download, no good for video upload Blog: http://funmore-residence.blogspot.com/ Forum: viewtopic.php?f=31&t=21109 Construction Start - 19/09/09 Slab Poured - 21/10/09 Frame Completed - 25/11/09 Lockup - 22/12/09 Fixing - 22/02/10 Handover & Moved In 30/04/2010 Re: ADSL 1500KB Speed 3Sep 03, 2009 3:07 am <has ADSL2+ on naked line..@16MB/s..... used to be on much worse when i was living with a relo for awhile... 1.5 is ok tho that would be depending on any combination of the following. 1: Distance from the exchange 2: Age of the copper in the street 3: Age of copper in your house 4: Type of phone outlet you have..... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: ADSL 1500KB Speed 4Sep 03, 2009 8:57 am I too have 1500K as it's the best I can get in my area. It's OK... Re: ADSL 1500KB Speed 5Sep 05, 2009 4:35 pm I used to have 1500k general actual download speed was around 100-120 kbps. Re: ADSL 1500KB Speed 6Sep 07, 2009 8:54 am maxyb Rhythm no good for video upload Upload speed is normally different from the download speed, and may vary between plans that have the same download speed. If you would like a faster upload speed, it may pay to check the business plans offered by the various providers who cover your address. Don't forgot, currently it is easy in Australia to acquire an ABN if being able to quote your ABN is important. Pfiff Finally making progress again, with a clothesline (yippee) and some much needed little things being attended to over the holidays. 40 C on New Year's eve? We love our a/c! Re: ADSL 1500KB Speed 7Sep 07, 2009 8:57 am Pugs ...that would be depending on any combination of the following. 1: Distance from the exchange 2: Age of the copper in the street 3: Age of copper in your house 4: Type of phone outlet you have..... What mechanism underlies a relationship between the age of copper wiring and the transmission rate that can be maintained over the wiring? Pfiff Finally making progress again, with a clothesline (yippee) and some much needed little things being attended to over the holidays. 40 C on New Year's eve? We love our a/c! Re: ADSL 1500KB Speed 8Sep 07, 2009 10:25 am Fiffaro Pugs ...that would be depending on any combination of the following. 1: Distance from the exchange 2: Age of the copper in the street 3: Age of copper in your house 4: Type of phone outlet you have..... What mechanism underlies a relationship between the age of copper wiring and the transmission rate that can be maintained over the wiring? Installtion methods, how brittle it is and such too many other variants to list really. i personally know that the **** black cable form the 1970's doesn't like adsl2 signals neither does 1950's lead lined stuff aswell. most cablers use Cat5e for lead in cables from the NTD to any first point and barely use internal phone wiring (cat3) anymore if they don't have to Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: ADSL 1500KB Speed 9Sep 25, 2009 1:41 am We are on 9500/250(this is average speeds), we absolutely love it and are not looking forward to crossing over to wireless when our house is finished. Re: ADSL 1500KB Speed 10Oct 09, 2009 2:25 pm zorelina Making use of both a Virgin Media (Cable) and BT (ADSL) broadband connection at the same time? I have a Virgin Media cable connection that has been providing a broadband connection to my home network of 6 PCs. I have recently added a BT ADSL connection that also could provide the broadband connection via a BT Home Hub. I would like to use both WAN connections and load balance them. Hey Zorelina, you do realise this Forum is based in Australia and the vast majority of users are Aussie and Kiwi? Not sure if your comment is relevant at all... Re: ADSL 1500KB Speed 11Oct 16, 2009 11:11 am zorelina Making use of both a Virgin Media (Cable) and BT (ADSL) broadband connection at the same time? I have a Virgin Media cable connection that has been providing a broadband connection to my home network of 6 PCs. I have recently added a BT ADSL connection that also could provide the broadband connection via a BT Home Hub. I would like to use both WAN connections and load balance them. Because of the way TCP/IP works, you will not be able to aggregate different gateways without the cooperation of your ISPs and the use of special routers. This level of support is normally only available for the big boys paying lots of money and not on ADSL type connections. Hence, you would not be able to use this approach to download a large video file quicker, for example. Multiple gateways can be combined so that different TCP/IP sessions use the different links. Hence, you could download a video using Virgin Media whilst downloading another video using BT. This method provides automatic failover if one link goes down. There are a number of commercially available solutions, such as PowerLink and ClariLink. Try googling those. Pfiff Finally making progress again, with a clothesline (yippee) and some much needed little things being attended to over the holidays. 40 C on New Year's eve? We love our a/c! |
