Browse Forums Home Theatre & Automation 1 Aug 23, 2009 8:45 pm Hi all that know a lot more about this than I do. I am planning on mounting my 50 inch plasma on the wall in my older '60s house. As is the usual drama with this I am hoping to run all the cables down through the wall cavity in some flat ducting to keep it all neat and tidy. My question is this. Will there be any affect running the power cable next to the RCA's/coax cable etc ?! Re: Mounting Plasma on wall and hiding wires in OLD house 2Aug 23, 2009 9:38 pm MarcB Hi all that know a lot more about this than I do. I am planning on mounting my 50 inch plasma on the wall in my older '60s house. As is the usual drama with this I am hoping to run all the cables down through the wall cavity in some flat ducting to keep it all neat and tidy. My question is this. Will there be any affect running the power cable next to the RCA's/coax cable etc ?! not at all. just use good quality sheilded cables. [url]ACMA registered cable, Government endorsed Antenna Installer[/url] Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5878 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 8070 |
