Browse Forums Home Theatre & Automation Re: New HT layout and projector + IMG 5Aug 19, 2009 5:59 pm kimberley - HD LCD projector (What other specs? Throw, Lumens, Size?) The only spec here that may be a factor in selecting a projector is the Throw, but much more importantly is how good the picture looks and how much it costs - once you have selected the projector based more in those two things (I'm sure others can add some important criteria here...) then you need to have a look at it's Throw specs and see what range of screen size it can accommodate in your room. kimberley - Screen MAX 96", but I agree smaller like 70" would more suit the small room. Well, I might have said go as small as an 84" or somewhere in that vicinity, but I think 70" is too small for the trouble... Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6144 Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8423 |
