Browse Forums Home Theatre & Automation 1 Jul 29, 2009 3:18 pm Hi there From the previous posts I have read, it is illegal to install any cabling that will be or may be connected to hte telsta network (might blow it up ) unless a registered cabler does the job. I was wondering am i allowed to install a draw wire in the framing, and get a registered cabler to install the cabling after handover. thanks in advance Re: installing draw wire 2Jul 29, 2009 4:17 pm eggman Hi there From the previous posts I have read, it is illegal to install any cabling that will be or may be connected to hte telsta network (might blow it up ) unless a registered cabler does the job. I was wondering am i allowed to install a draw wire in the framing, and get a registered cabler to install the cabling after handover. thanks in advance why would you want to install draw wire if cable can be and should be installed ? What would you do if the draw wire would get stuck when pulling cables ? At frame stage no cable is connected to Telstra network, but this job should be done by registered cabler. [url]ACMA registered cable, Government endorsed Antenna Installer[/url] Re: installing draw wire 4Jul 29, 2009 8:49 pm we had draw wires installed in conduit so we could get a cabler in after hand over. For one of the draw wires the electrician( who was the one putting the conduits etc in) tried to just use a draw wire with no conduit. BUT we insisted on the draw wire going in a conduit since we'd paid for one and I was worried about it getting stuck or catching . ( we have double brick and there were regular ties between the wall insulation and the 2 brick layers. We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16289 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6701 |
