Browse Forums Home Theatre & Automation 1 Jul 27, 2009 8:02 pm Hi all, (Bernie here, login password forgot) I am looking to mount a 50" Panasonic Viera TCP50G10 on our wall. Trouble is, it is above our gas fireplace so the "Main" studs that run to the floor are 1M apart. There is another stud inbetween however that is cut half way down for the gas unit. So my asumption was I will need to get a mount to bolt to the 1M stud's.... Now, I have had alook around. It seems the largest I can get (Fixed with 15degree tilt) is~980MM (for holes). Does anyone know a mount kit that has bolt holes 1M apart? Otherwise I will be making my own 1M metal bracket and then mount a "normal" plasma mount kit to that. Hope that makes sense? P.S. Please do not turn this into a "do/don't mount above fire place debate, I have already made up my mind " Bernie. nesspop Why am I covered in feathers Re: Mounting 50" Panasonic on wall - Studs 1M apart 2Jul 27, 2009 8:27 pm Don't mount above the fireplace Re: Mounting 50" Panasonic on wall - Studs 1M apart 4Jul 27, 2009 10:45 pm if you are still at frame stage get extra noggins/ or get peices of wood screwed into the studs Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Mounting 50" Panasonic on wall - Studs 1M apart 5Jul 28, 2009 7:52 am nesspop Hi all, (Bernie here, login password forgot) So my asumption was I will need to get a mount to bolt to the 1M stud's.... Now, I have had alook around. It seems the largest I can get (Fixed with 15degree tilt) is~980MM (for holes). Bernie. there is a larger bracket you can get, 1.2 or 1.3 mt long. We used to mount 63" Samsung on one of these. Prety sure cusomer got it from HN. unfortunately don't remeber the price or manufacturer. [url]ACMA registered cable, Government endorsed Antenna Installer[/url] Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5835 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5142 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16105 |
