Browse Forums Home Theatre & Automation Re: Ask your Home Theatre questions here... 201Sep 07, 2009 4:19 pm What are your thoughts on speaker wall plates? I ran speaker wire to the back of my theater and instead of just leaving the wires hanging out of a hole in the wall, I'm thinking of putting in speaker wall plates. Re: Ask your Home Theatre questions here... 202Sep 07, 2009 4:53 pm ![]() What are your thoughts on speaker wall plates? I ran speaker wire to the back of my theater and instead of just leaving the wires hanging out of a hole in the wall, I'm thinking of putting in speaker wall plates. i would use these hands down... makes it neater also less likey for kids to do anthing to themselfs on exposed wires then Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Ask your Home Theatre questions here... 205Sep 07, 2009 7:01 pm ![]() How about banana plugs? I read that they help prevent loose wires from touching and helps prevent/slow oxidation of the speaker wires. bannan plugs, binding posts.. those "average" push pin ones... each to their own really depends on what look you are after Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Ask your Home Theatre questions here... 206Sep 08, 2009 1:17 pm Regarding speaker wallplates - it depends on what types of speakers you are mounting and how: If they are going to be mounted with their backs hard up against the wall (or near enough too) then there simply isn't room for wallplates and you simply run the speaker wire through a small hole behind the speaker that the speaker itself covers. If they are small speakers then the wallplate will stick out and you might not like that look either - it may in fact be less 'industrial' to also simply have the wire poke through a small hole - often these holes can be covered by the base of the bracket itself. Only if you are using brackets that suspend the speaker away from the wall and the options above aren't applicable would you then consider using wallplates to terminate those speaker connections. Regarding plugs - I agree with Pugs here - each to their own. I almost never use banana/blade/spike plugs (I only use banana plugs in situations where I actually need to change the speakers over on a regular basis - like demo'ing different speakers... Re: Ask your Home Theatre questions here... 207Sep 10, 2009 12:37 am guys want to ask sumthing i want to put projector in one of my room, its 4.3 by 4 metres room, what projector can i go for ? any recommendation ? thanks Re: Ask your Home Theatre questions here... 208Sep 11, 2009 7:05 pm Anyone know what gauge (AWG) this speaker wire is? The salesmen don't have a clue what AWG is http://www.radioparts.com.au/ProdView.a ... ABLE+(150M) Re: Ask your Home Theatre questions here... 209Sep 11, 2009 11:59 pm ![]() Anyone know what gauge (AWG) this speaker wire is? The salesmen don't have a clue what AWG is http://www.radioparts.com.au/ProdView.a ... ABLE+(150M) $7.50 per metre and the salesman doesn't know what the guage is ![]() Try Selby for some decent 10 or 12 AWG stuff. Re: Ask your Home Theatre questions here... 210Sep 12, 2009 1:06 am AWG is American Wire Gauge... as ithe size of the copper inside... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Ask your Home Theatre questions here... 211Sep 12, 2009 8:57 am ![]() guys want to ask sumthing i want to put projector in one of my room, its 4.3 by 4 metres room, what projector can i go for ? any recommendation ? thanks You can go for any projector you think gives a good image - it depends on what size screen you want. I think you need to do some more reading in here first (the subject gets covered heaps in here...). Re: Ask your Home Theatre questions here... 212Sep 13, 2009 7:54 pm ![]() Anyone know what gauge (AWG) this speaker wire is? The salesmen don't have a clue what AWG is http://www.radioparts.com.au/ProdView.a ... ABLE+(150M) Its Monster and that IMO says it all! ![]() Try http://www.selbyacoustics.com.au/storef ... =246732474 This stuff is nearly as thick as a small childs finger ![]() For a full range check here: http://www.selbyacoustics.com.au/storef ... 20&c=84104 or here: http://uglycable.com.au/storefrontprofi ... 3&c=698736 Re: Ask your Home Theatre questions here... 213Sep 14, 2009 7:02 pm ![]() Try T This stuff is nearly as thick as a small childs finger ![]() For a full range check here: http://www.selbyacoustics.com.au/storef ... 20&c=84104 or here: http://uglycable.com.au/storefrontprofi ... 3&c=698736 Love the Selby speaker cables. Just installed some 12 AWG stuff myself. I was lead to believe that not all equipment and not all banana plugs can take the 10 AWG thickness cables - is that true ? Re: Ask your Home Theatre questions here... 214Sep 21, 2009 5:00 pm HI, We are building our new house and in the main living area I plan to have a plasma and new reciever with a 5.1 speaker setup (Dont think we need 7.1). The rear speakers will be in the ceiling and I plan to use a wall plate, run the speaker cable inside the wall, accross the joists until I get to the speaker. The run will be approx 8m including up the wall. My 3 questions are: - Should I use "insulated" speaker cable or just normal speaker cable (quality of course) - With wall plate should I use banana plugs to go from the reciever to the wall plate or would binding post be fine? - With the AWG rating the lower the number the thicker the cable right? Any advice would be greatly appreciated Cheers ![]() Blog: http://funmore-residence.blogspot.com/ Forum: viewtopic.php?f=31&t=21109 Construction Start - 19/09/09 Slab Poured - 21/10/09 Frame Completed - 25/11/09 Lockup - 22/12/09 Fixing - 22/02/10 Handover & Moved In 30/04/2010 Re: Ask your Home Theatre questions here... 215Sep 21, 2009 5:32 pm ![]() HI, We are building our new house and in the main living area I plan to have a plasma and new reciever with a 5.1 speaker setup (Dont think we need 7.1). The rear speakers will be in the ceiling and I plan to use a wall plate, run the speaker cable inside the wall, accross the joists until I get to the speaker. The run will be approx 8m including up the wall. My 3 questions are: - Should I use "insulated" speaker cable or just normal speaker cable (quality of course) - With wall plate should I use banana plugs to go from the reciever to the wall plate or would binding post be fine? - With the AWG rating the lower the number the thicker the cable right? Any advice would be greatly appreciated Cheers ![]() I'll kick things off, while I'm around the place ... - Not sure if specially "insulated" speaker cable will really make a difference. All cable is insulated either by a clear plastic or by an opaque plastic. Worse case scenario is that you can always replace it, because it will be accessible. I guess if you really really wanted to be safe (let's say if you bought some $1000/ft cable ![]() - Binding post would be fine. For convenience, I like to have at least one end with banana plugs (usually the wallplate end) so that I can quickly unplug if I need to move or pull things out etc... Make sure you label all of the cables and the speaker plates. - Yes. Lower AWG number is better as it indicates thicker cable with more copper strands. 10 or 12 AWG would be great. I still think that not all equipment and not all banana plugs will accept 10 AWG - but that hasn't been confirmed by anyone. You can buy rolls of 25m from Selby, which would suit you nicely and leave enough to handle all of your shorter runs for front/centre speakers. Re: Ask your Home Theatre questions here... 216Sep 21, 2009 5:43 pm ![]() ![]() HI, We are building our new house and in the main living area I plan to have a plasma and new reciever with a 5.1 speaker setup (Dont think we need 7.1). The rear speakers will be in the ceiling and I plan to use a wall plate, run the speaker cable inside the wall, accross the joists until I get to the speaker. The run will be approx 8m including up the wall. My 3 questions are: - Should I use "insulated" speaker cable or just normal speaker cable (quality of course) - With wall plate should I use banana plugs to go from the reciever to the wall plate or would binding post be fine? - With the AWG rating the lower the number the thicker the cable right? Any advice would be greatly appreciated Cheers ![]() I'll kick things off, while I'm around the place ... - Not sure if specially "insulated" speaker cable will really make a difference. All cable is insulated either by a clear plastic or by an opaque plastic. Worse case scenario is that you can always replace it, because it will be accessible. I guess if you really really wanted to be safe (let's say if you bought some $1000/ft cable ![]() - Binding post would be fine. For convenience, I like to have at least one end with banana plugs (usually the wallplate end) so that I can quickly unplug if I need to move or pull things out etc... Make sure you label all of the cables and the speaker plates. - Yes. Lower AWG number is better as it indicates thicker cable with more copper strands. 10 or 12 AWG would be great. I still think that not all equipment and not all banana plugs will accept 10 AWG - but that hasn't been confirmed by anyone. You can buy rolls of 25m from Selby, which would suit you nicely and leave enough to handle all of your shorter runs for front/centre speakers. Thanks for that. I didnt know there was insulated or more accurately double insulated speaker cable avaiable until I started searching but will now probably stick with good quality speaker cable around the 10 or 12 AWG. I did plan to use bananna plugs from the reciever to the wall plate so it would appear I am not too far off the mark with my plans Thanks again Blog: http://funmore-residence.blogspot.com/ Forum: viewtopic.php?f=31&t=21109 Construction Start - 19/09/09 Slab Poured - 21/10/09 Frame Completed - 25/11/09 Lockup - 22/12/09 Fixing - 22/02/10 Handover & Moved In 30/04/2010 Re: Ask your Home Theatre questions here... 217Oct 04, 2009 1:22 am Hi guys, here's some food for thought. A chap I know fairly well who designs hi-end loudspeakers (Greg Osborn) recommended I use 4 strands of Cat 5 to the rear speakers. At 20cents a meter and a band width to die for so your rears respond quickly etc etc, why spend the mega bucks when you don't have to. PD Hayman 34 H1 Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=29460&start=0 Blog http://miazfolly.blogspot.com Tiles 25/3/09 Colors 6/4/09 Tender 7/5/09 Contract 28/5/09 Land 16/11/09 Re: Ask your Home Theatre questions here... 218Oct 04, 2009 10:07 am The cost of 4 runs of Cat5E is more than I would spend on speaker cable to my rears - and I'm planning on using speakers that are considerably more than $1K a pair for rears too. "Respond quicker"? Please - no one here spends anywhere near what it would take to actually notice any such difference in your rear speakers. Greg is comparing the cost to speaker cable worth over $50 a metre, and I say again, you wouldn't hear the benefit that kind of speaker cable could offer unless you were dealing with very High-End speakers (which I know Greg makes - I've already said in here he actually makes my favourite speakers...) and you had seriously tamed the room they operate in... Re: Ask your Home Theatre questions here... 219Oct 04, 2009 8:02 pm I've done plenty of reading on speaker cables because I wanted to prewire our HT. Its funny how reading up on speaker cables reads like the great debates on LCD vs Plasma, Cat5 vs Cat6, the Beatles vs Rolling Stones etc....it just never ends Anyway, not wanting to start a speaker cable debate here but 16 AWG would be more than enough for runs of up to 14 meters. 12 AWG for a run of say 10 meters would be overkill when 16 AWG is sufficient. This guy has really good credentials and has some good points on the topic of speaker wires http://www.roger-russell.com/wire/wire.htm#wiretable Re: Ask your Home Theatre questions here... 220Oct 11, 2009 11:27 am Hi, Even though our house is only at brick stage, I'm starting to look at home theatre stuff so I can keep an eye out for cheap prices. And also, I've read this whole thread, and a lot of others ones on here, and I don't understand anything!!! And I've tried guides on cnet too, but I'm still confused... I know what a Cat5 cable looks like from my work and that's the limits of my tech savviness - I don't even know what they do. We have bought the LG HT303SU Home Theatre set with a nice big discount as it's enough for our needs. I know it's certainly not the top of any model, but I'm not that fussed about perfect sound, and the guys at work said that it's good value for money, especially at the discount we bought it for, for what we want and the size of the room, and now I need to work out what else to get. And I am not very tech savvy at all, so I would like some advice. Well, more likely I think I need advice......... We want to put a projector up because it's a room with no windows and they're cheaper than big TVs and it's kinda cool. The length of the room is 4.04m and I'm thinking of mounting the projector very close to the back wall so the picture is bigger (that's how it works, right?). The only thing I would like is to have good picture. I won't be operating it (as I don't think my OH will trust me) so as long as I have a nice, clear picture, and I can hear what people are saying, I'll be happy. I would like to connect the projector to the TV in the family room so when we eventually have foxtel, we can just share it in there. We will have separate DVD players in each room in case we want to watch something different and because we have 2 now anyhow, and maybe seperate set top boxes too, but I'm not sure about that as it's not really needed, I think we'd just watch movies in there... But the opportunity would be nice. I guess it depends how cheap they are. I'd also like to stick my computer in too as it's got some movies on it. So pretty much all we have left to buy is the receiver, projector, maybe a set top box and cables to connect that all together and to the other TV, right? Or have I got it wrong and we'll need other stuff too? I've been looking at projectors on CNET too. I'm willing to spend up to $2000 (of course, if it's cheaper I'd be happy with that), maybe a bit more if someone thinks that a certain model is too good to refuse. 3 I've found that look good and are quite cheap (to me, maybe I'm wrong) are: http://reviews.cnet.com/home-theater-pr ... 20107.html http://reviews.cnet.com/home-theater-pr ... 49715.html http://reviews.cnet.com/home-theater-pr ... 88317.html Or am I off and another would be good? And would there be compatibility problems with any of these with receivers? Like I have to buy certain receivers with projectors? I've also looked at 1080HD projectors which are more expensive (but obviously are clearer). Will they be better for that space? Or as it's only 4m across, would it be better at 720? Ardo That is so funny! I wonder how many people know who Larry Haun is these days. I have a couple of young guys we call Mo 1 & Mo 2 who run a crew of 6 boys and… 9 6382 ![]() Your kinda doing this arse about. Engage in a draftsman/architect first. They will guide you on what you need to do. You risk soil test being done in the wrong location… 4 3865 I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 2544 ![]() |
