Browse Forums Home Theatre & Automation 1 Jun 19, 2009 3:12 pm Hi everyone... I want to install a 5.1 sound system - but ONLY want to install cabling in the walls for my two rear speakers. So, on one side of the room (where my TV and AVR sit), I want two wall plates near the floor, and at the rear of the room, two wallplates high up (where I'll mount the rear speakers). My builder quoted $77 "per speaker point"... That seems to indicate it costs $154 *per speaker*.... So, to have my two rear speakers cables (with wallplates), it'll cost $308. This seems a bit excessive to me.... (they charging $62 per data point, which is better... I thought it'd be cheaper to install audio cabling!). Re: Speaker cabling costs... my quote from the builder 2Jun 19, 2009 3:49 pm no thats correct..that includes labour too so ... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Speaker cabling costs... my quote from the builder 3Jun 19, 2009 10:52 pm Sounds about right albeit as we know damn exy.. We are paying $378 for running cable with banana plug wall plates... just easier for builder to do it.. What is another $300 on $300k?? Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Speaker cabling costs... my quote from the builder 4Jun 20, 2009 11:04 am That does seem a little high to me, and when I first started reading I thought the $77 per run was good value, but if you are essentially being charged that amount twice per run because it's being terminated at both ends!?!? then I too think that's excessive. That said, if it's the only thing this tradie is supplying/installing then there needs to be some consideration for driving out to your place twice to complete this piece of work... Re: Speaker cabling costs... my quote from the builder 5Jun 20, 2009 10:34 pm webbiegareth My builder quoted $77 "per speaker point"... That seems to indicate it costs $154 *per speaker*.... So, to have my two rear speakers cables (with wallplates), it'll cost $308. To me, $77 per speaker point is the same as $77 per speaker location, i.e. point at which there is a speaker. I'm not sure why you think it'd be double per speaker? It makes no sense to quote that way. Re: Speaker cabling costs... my quote from the builder 6Jun 21, 2009 12:17 pm I saw it as "per point"... being "per wallplate installed" (i.e. one on each length of the cable). I'm just very pessimistic, as whenever I get quotes for things from the builders - they always seem hugely excessive (so I was just preparing for the worst). If it's only $77 per speaker, I'll definitely get them to do it... if it's double that, then I'll probably just get it done after handover... (or get the electrician to do it while he's onsite for a much cheaper price!). I'm assuming they didn't have a dedicated speaker guy come out to install the cable, and they'd have one electrician/data cabler do the work (as I am definitely getting the house networked, no matter what). Re: Speaker cabling costs... my quote from the builder 7Jun 23, 2009 1:10 pm Hi everyone... I will now follow up with the outcome, and why I was so confused! They quoted me "$77 per speaker point", which as it turns out, really is just "per speaker" - so it's going to cost $154 to cable the two rear speakers. I'm much happier with that. They also quoted "$62 per data point".... But this truly is "per point". So, if I have a network cable reaching from the lounge to a bedroom, they count that as two points, not "per run". So it's $62x2 for the cable. I'm doing four network cables back to a central point, so that's $62x8 ($496 in total). Re: Speaker cabling costs... my quote from the builder 8Jun 23, 2009 8:00 pm As i mentioned its the "Price of Convenience". Like with many home building items.. maybe cheaper to do later but could you be bothered to do it then. Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Speaker cabling costs... my quote from the builder 9Jun 23, 2009 11:15 pm webbiegareth Hi everyone... I will now follow up with the outcome, and why I was so confused! They quoted me "$77 per speaker point", which as it turns out, really is just "per speaker" - so it's going to cost $154 to cable the two rear speakers. I'm much happier with that. They also quoted "$62 per data point".... But this truly is "per point". So, if I have a network cable reaching from the lounge to a bedroom, they count that as two points, not "per run". So it's $62x2 for the cable. I'm doing four network cables back to a central point, so that's $62x8 ($496 in total). average price for an install is about $120 - 180 per run (wall plate to wall plate) 180 for fewer points where as 120 is about 20- 30 points Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal 10 15680 hey there! π so, itβs kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20855 I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I… 5 14272 |
