Browse Forums Home Theatre & Automation Re: Ethernet Points - costs to do before plastering, etc 21Jul 24, 2009 9:52 am We've organised with the builder to go in and put the cables in ourselves, as long as it's not electrical, CAT-6 or speaker wires and marked, it's not a problem. We'll just install the face plates ourselves after we've moved in. Skin Re: Ethernet Points - costs to do before plastering, etc 22Jul 24, 2009 5:07 pm skin We've organised with the builder to go in and put the cables in ourselves, as long as it's not electrical, CAT-6 or speaker wires and marked, it's not a problem. We'll just install the face plates ourselves after we've moved in. I'm guessing you really mean is you are getting your own data guy to come and in install that part of the job... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Okay sorry silly me, my wife has solves the mystery for me. It’s because the labels on the ports are all wrongly positioned by the builder hence it confuses me. 2 1380 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8306 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13846 |
