Browse Forums Home Theatre & Automation 1 Jun 04, 2009 7:41 pm Okay, so when everyones talking about data points.. ect. I have no idea what they are talking about. I'm technilogically challenged. (And clearly not a very good speller) We are getting a smart wiring pack as part of our estate guidelines and we'll have data points everywhere (well, almost) I'm just wondering.. my friend was mentioning being able to watch movies on his t.v. in the main living area from his computer harddrive in his study on his t.v. which is in another room as part of their smart wiring pack. Will I be able to do this is I have two data points in our study and 2 data points where the T.V. is? Is this what data points do? Building with PD - Regent 23 Cascades on Clyde Estate HomeOne Building Thread - PCI Completed - 28th August. Handover - 11th September. Re: Clueless - Smart Wiring Data Points? 2Jun 04, 2009 9:29 pm data points are places where you can plug an ethernet enbaled device into the home network, be it a Voip phone a PC, notebook or which ever.. but when smart wiring you have a central point in the house where the LAN (Local Area Network) is terminated with a patch panel of sorts so you can patch a networked device so it can reach another service be i tia home server or the internet. I t also means you can patch phone signals around the house aswell to any point. if you would like it explained to you over the phone my number is in my sig... when building a house and gettting in a propper data cabler they will talk you through the entire project and be able to supply any extra gear you may need where as a builder package will run the cables and terminate to the wall plates then leave you twisting in the wind Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13864 Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20677 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16289 |
