Browse Forums Home Theatre & Automation Re: Advice on Wall plates etc 2May 28, 2009 3:23 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Advice on Wall plates etc 4May 28, 2009 3:42 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Advice on Wall plates etc 8May 29, 2009 8:01 pm What I suggest is a combination of bits, but at least it's modular and you can replace/upgrade one piece at a time instead of the entire puzzle. You can get IR repeating systems for less than $200 ($300 if you want one that's guaranteed to work with Foxtel): http://www.selbyacoustics.com.au/storef ... =244548511 http://www.selbyacoustics.com.au/storef ... =245078924 Component Video AV Distribution amplifiers (1in-4out) for less again: http://www.selbyacoustics.com.au/storef ... =247650285 even for HDMI... You can completely customise the setup for your specific needs. Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17542 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6901 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 45795 |
