Browse Forums Home Theatre & Automation 1 May 26, 2009 9:56 am Hi everyone, my first post here.... I have a rumpus where there's a fireplace where I plan on having a tv also in the same spot above it...my only problem is how to mount it? - have read other posts about having the tv near fireplace and understand as long as it doesnt sit too close it should be fine My first thought was to have a wall mount but not sure if that's even do-able as I assume there would b a chimney/flu kit pipe that runs through where the purple box is in my pic. 2nd idea was to have it hanging from the ceiling in either of the two places (green/yellow circles) as there's a slight ledge where the downlights...has anybody done this before? I'll have a pro take a look for advice on how to properly get it installed but would appreciate any ideas/alternatives..but so far think hanging it will be the best way Thanks! Here's a pic of the area in question, tv size is going to be probably 60" or slightly bigger/smaller, so the mounts will be heavy duty obviously... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Hanging LCD/Plasma from ceiling? 2Jun 01, 2009 9:33 pm i think a roof mount would be the way to go as the flu in the wall would be a big problem with the size your looking at. there is these guys that do roof lift kits but im guessing it would cost more then the screen. http://www.youtube.com/watch?v=FgVJ9QEfubo http://www.ultraliftaustralia.com.au/ Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10684 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5936 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2452 |
