Browse Forums Home Theatre & Automation Re: What does this mean? 4May 15, 2009 11:00 am Building in Harvest Lakes, Atwell (Perth) status: design phase with builder Re: What does this mean? 7May 15, 2009 12:49 pm Building in Harvest Lakes, Atwell (Perth) status: design phase with builder Re: What does this mean? 9May 15, 2009 2:20 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: What does this mean? 10May 15, 2009 3:01 pm championboxer (b) the LAN cable is for video/audio. What if i like internet access in the rooms as well? Is it the same cable? or i need to install another CAT5e/CAT6 cable solely for internet access? Rooms that are close, i can consider wireless. Thanks As Rodda has indicated, run multiples of LAN cables to those rooms that you require Internet access. Remember the audio/video streaming device will usually be away from the area in the room where you’ll be using the Internet. You should avoid having cables draping over the floor, likewise adding switches to a LAN cable is relatively cheap and easy to do; but IMO can and does become unsightly, much better to have these type of devices out of sight. WiFi is also another option for some of your Internet devices. Re: What does this mean? 11May 15, 2009 3:17 pm much understood.. thank you all... guess the next step is trying to find someone to do the cabling.... is starserve system recommended? Building in Harvest Lakes, Atwell (Perth) status: design phase with builder Re: What does this mean? 12May 15, 2009 4:38 pm all depends on your needs Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: What does this mean? 13May 15, 2009 4:42 pm Pugs all depends on your needs if its based on the needs illustrated in my attached image earlier? thanks! Building in Harvest Lakes, Atwell (Perth) status: design phase with builder Re: What does this mean? 14May 15, 2009 7:23 pm depnds also if you wan tot distro TV signals aswell... IMO star serve is good if you have or are wanting to have foxtel/ other "TV" distro'ed around the house... and even to a point some of their parts are ok but ther networking gear is far form great..... tho if you are serious about good Networking and TV signal distro I'd go for Hills/clipsal TV distro gear and then leave the networking side clear of it and be a seperate enity terminated in the study... while 100Mb is fine for most avi and such when you are talking large files that are blue ray disc's you are better off having some head room in the network and using GigE gear esp if you have others trying to use the network at the same time. even with two runs two each room that is 12 runs ... so all that is is 2 x 6way wall plates... and a seperate single gang wall plate for the incoming phone.... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: What does this mean? 15May 15, 2009 8:15 pm Pugs IMO star serve is good if you have or are wanting to have foxtel/ other "TV" distro'ed around the house... and even to a point some of their parts are ok but ther networking gear is far form great..... tho if you are serious about good Networking and TV signal distro I'd go for Hills/clipsal TV distro gear and then leave the networking side clear of it and be a seperate enity terminated in the study... while 100Mb is fine for most avi and such when you are talking large files that are blue ray disc's you are better off having some head room in the network and using GigE gear esp if you have others trying to use the network at the same time. Why would you suggest separating the TV and data circuits to different areas if they are considering to install a product along the lines of Starserve? Re: What does this mean? 16May 15, 2009 8:48 pm honestly some days i just don't care about anyone else in other states that i wouldn't be doing the work for anyways and they should realy start talking to data cablers/ tv guys in their own area...... and without talking to a client directly i have no friggin idea what the heck they want esp when they have no real idea on what they want to achieve out of the system >????? and I'm only pointing out things that the OP can look into..... http://updates.clipsal.com/ClipsalOnlin ... de=63&ref= <star serve Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: What does this mean? 17May 15, 2009 8:50 pm Pugs honestly some days i just don't care about anyone else in other states that i wouldn't be doing the work for anyways and they should realy start talking to data cablers/ tv guys in their own area...... and without talking to a client directly i have no friggin idea what the heck they want esp when they have no real idea on what they want to achieve out of the system >????? and I'm only pointing out things that the OP can look into..... your pointers are much appreciated! Building in Harvest Lakes, Atwell (Perth) status: design phase with builder Re: What does this mean? 18May 15, 2009 8:54 pm championboxer your pointers are much appreciated! no worries sorry for the vent it is hard when working and pumping out quotes all day and people reject them without discussing what they actaully need (realistacally) Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal I've just built 3 stairs off a landing out the back and been told by the private certifier I need hand rails sorry tried to attach a pic but couldn't mine don't have sides… 5 5722 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12796 Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12671 |
