Browse Forums Home Theatre & Automation 1 Apr 25, 2009 6:15 pm Hi all, We have a few questions which we're trying to get answered so any tips you can provide would be gratefully received. When installing an HT with floorstanding fronts and a sub-woofer to the side do most people have the wires showing or do they pass them through the walls so that the speakers are flush against the wall with no wire showing? We're considering wall mounting our TV with an HT unit below the TV with the components and centre speaker. We'll have 2 floorstanding fronts and the sub to the side. We'll also be putting in centre L and R and rear L and R speakers as in-ceiling speakers. Would the wiring for this be a lot easier if done during the build or is it not much different if done after the build? I remember Rodda saying in another thread that with Colorbond rooves putting in wires can be more awkward than with tiles, and as we are looking at a steel frame house with a Colorbond roof we're trying to work out what needs to be done at the time of build vs. later. Thanks, PN Re: Wiring before or after build - steel frame & colorbond house 2Apr 26, 2009 11:46 am at build at frame stage as with steel frames you need special gromets installed to protect the cables.. also to ensure you are seperated from electricals and other services Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Wiring before or after build - steel frame & colorbond house 3Apr 26, 2009 1:11 pm Pugs at build at frame stage as with steel frames you need special gromets installed to protect the cables.. also to ensure you are seperated from electricals and other services Thanks mate. Would this apply equally to just speaker cables (which is what we would be running) as opposed to the HDMI, CAT5, power and other types of cables that others run for their HT setups? Re: Wiring before or after build - steel frame & colorbond house 4Apr 26, 2009 2:00 pm Pugs at build at frame stage as with steel frames you need special gromets installed to protect the cables.. also to ensure you are seperated from electricals and other services It is still possible and easier than timber frame as you would only need to put the grommets in the frame near the ceiling and drop the cables down (timber you would need to drill through the frame and also drill through the noggins which can be very hard, steel frame doesn't have noggins like timber frames).... The only thing you couldn't do is run the cables sideways through the wall as you wouldn't have the grommets but you wouldn't normally need to do that with anything except for the plumbing and you wouldn't be able to do that with timber frame anyway. Re: Wiring before or after build - steel frame & colorbond house 5Apr 26, 2009 3:18 pm wakeboardandy The only thing you couldn't do is run the cables sideways through the wall as you wouldn't have the grommets but you wouldn't normally need to do that with anything except for the plumbing and you wouldn't be able to do that with timber frame anyway. Thanks wakeboardandy. So are you saying that running speaker cables sideways from the centre of the wall (where the receiver would sit) to the L and R front speakers, and to one side for the sub would be hard to do after building as these would be sideways through the wall? Re: Wiring before or after build - steel frame & colorbond house 6Apr 26, 2009 4:26 pm purpleninja Thanks wakeboardandy. So are you saying that running speaker cables sideways from the centre of the wall (where the receiver would sit) to the L and R front speakers, and to one side for the sub would be hard to do after building as these would be sideways through the wall? yes that would be hard, but my front speakers will be floor standing so didn't see the point of running cables in the wall for those. Re: Wiring before or after build - steel frame & colorbond house 7Apr 26, 2009 4:33 pm wakeboardandy yes that would be hard, but my front speakers will be floor standing so didn't see the point of running cables in the wall for those. Thanks for the info Our front speakers will be floorstanding as well. I know it's a personal preference decision but do most people show the wires for floorstanding speakers and sub, or do they put the cables behind the walls? Re: Wiring before or after build - steel frame & colorbond house 8Apr 26, 2009 9:22 pm purpleninja Pugs at build at frame stage as with steel frames you need special gromets installed to protect the cables.. also to ensure you are seperated from electricals and other services Thanks mate. Would this apply equally to just speaker cables (which is what we would be running) as opposed to the HDMI, CAT5, power and other types of cables that others run for their HT setups? applies to all cables/ services reguardless Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Wiring before or after build - steel frame & colorbond house 9Apr 26, 2009 9:35 pm Pugs applies to all cables/ services reguardless Thanks for the clarification. Is it purely a matter of ease of access at the build stage, compared to crawling around an enclosed roof cavity after the build, or is there something else to it? Re: Wiring before or after build - steel frame & colorbond house 10Apr 26, 2009 9:46 pm purpleninja Is it purely a matter of ease of access at the build stage, compared to crawling around an enclosed roof cavity after the build, or is there something else to it? that's pretty much it.. Re: Wiring before or after build - steel frame & colorbond house 11Apr 26, 2009 9:48 pm purpleninja Pugs applies to all cables/ services reguardless Thanks for the clarification. Is it purely a matter of ease of access at the build stage, compared to crawling around an enclosed roof cavity after the build, or is there something else to it? both ... mainly to ensure you donpt interfre with any other services........... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Wiring before or after build - steel frame & colorbond house 12Apr 26, 2009 9:56 pm Pugs why can't a simple statement from a cabler not be questioned to the enth degree..... there will be rules and such that with out the training won't make sense to anyone other then licensed cablers so why not take our word?? we arn't posting misimformation we also simply don't like having to repost the rules every time we are questioned..... that's a little harsh and uncalled for.. purpleninja was just asking for clarification. Also the info you posted about steel frames was incorrect, so not everything you post on here is written in stone. Re: Wiring before or after build - steel frame & colorbond house 13Apr 26, 2009 10:09 pm Pugs why can't a simple statement from a cabler not be questioned to the enth degree..... there will be rules and such that with out the training won't make sense to anyone other then licensed cablers so why not take our word?? we arn't posting misimformation we also simply don't like having to repost the rules every time we are questioned..... I wasn't questioning it to the Nth degree for the sake of it, I was just curious as to the reason behind the explanation. If we end up not getting all our cabling done during the build it would be good to know if there were other factors that would come into play if we wanted to have work done post-build, and especially if there could be a situation where we couldn't have some things done after the build. Sorry if I caused offence - I was just curious and I like to know the reasons behind things. Re: Wiring before or after build - steel frame & colorbond house 14Apr 26, 2009 10:09 pm wakeboardandy that's pretty much it.. That's good to know. I was getting worried that there might be some things that couldn't be done post-build. Thanks mate - much appreciated Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14449 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8036 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8484 |
